Battery Cables
Old May 28, 2017 | 11:05 PM
THantzar's Avatar
Default Battery Cables
I need to replace the negative (and probably the positive) battery cable. The ones in the auto shops are too short. I see on Ebay that they run anywhere from $60-$130. What should I look for when ordering? Is there a place that you can suggest? I have a 2003 X-Type AWD with about 154,000 that I'm trying to bring up to speed. Thanks.
Old May 29, 2017 | 01:48 AM
JagXSE's Avatar
Try this UK seller; may be willing to arrange USA shipping.
JAGUAR X TYPE 2003 GROUND NEGATIVE BATTERY CABLE WIRE STRAP 4X43-14301 | eBay
It shows Jag Part # too
Old May 29, 2017 | 07:13 AM
Thermo's Avatar
Veteran: Navy
Thantzar, if you look at "Jaguarparts.com" (dealership out of Cleveland OH as I recall), they have both cables for $65 each. If you call up JPLV (sponsor here), they can probably get you them slightly cheaper than that and get you OEM parts. Most guys simply pull the cables off and go to the auto parts store and find a set that is close and buy those.
Old May 29, 2017 | 02:17 PM
Dell Gailey's Avatar
(?) Not true?
