Battery change
Old Apr 15, 2012 | 06:03 PM
Ar15fonsi's Avatar
Default Battery change
So i replaced my battery today, actually just finished doing it, and the only problem I have is that my One touch feature on my windows does not work anymore, If I press all they way down they go down all the way automatically but if I press all the way up they don't go up automatically ...
After messing with them pressing up and down, now the driver side works but the rest will not go up with the one touch feature.
The controls on my door fell the same not loose or sloppy or anything like that.
Any suggestions?
Thanks.
Old Apr 15, 2012 | 08:01 PM
Jaggy Jag's Avatar
That happen when you change battery...if you still have your owners manual...it will tell you the steps to set it back...it's a very easy task...
Old Apr 15, 2012 | 08:04 PM
Jaggy Jag's Avatar
If you don't have the manual...let me know...I will tell you the steps...
Old Apr 15, 2012 | 09:00 PM
Carwatcher's Avatar
on the driver's door just pull up and hold each of the four window buttons for about 5 seconds or so.
Old Apr 16, 2012 | 08:18 AM
Thermo's Avatar
Veteran: Navy
Ar15fonsi. What you need to do is to reset the auto up feature. What you will need to do is to pick a window and push (and hold) the button down to lower the window. Once the window reaches full down, keep holding the button down for another 2-3 seconds. Now, raise that same window by lifting (and holding) on the button. Again, once the window reaches the fully closed position, keep holding the button for another 2-3 seconds. Repeat for each window. This will restore the auto up/down feature.
Old Apr 16, 2012 | 10:40 AM
Ar15fonsi's Avatar
Thanks all for the help, got it resented..
Forcedair1
Sep 8, 2025 01:57 PM
al_roethlisberger
Sep 11, 2015 10:04 PM
OkieTim
Sep 8, 2015 04:48 PM
edtexas
Sep 4, 2015 08:20 PM
OkieTim
Sep 2, 2015 12:48 PM
