beep beep beep
Old Dec 21, 2007 | 08:02 AM
xtyperick's Avatar
Default RE: beep beep beep
Bruce,
Do us all a favor the add a FAQ if you can on changing the transfer case fluid. My X went in yesterday for a new one RIP @ 48K miles. I'll be changing the fluid on the new one frequently now.
Old Dec 21, 2007 | 06:17 PM
jasonzimbran's Avatar
What is a transfer case fluid. What role does it have. When does it have to be changed?
Old Dec 21, 2007 | 06:48 PM
SpartanX's Avatar
ORIGINAL: xtyperick
Bruce,
Was it leaking??? If so, then chances are that's why you had to buy one. Or were you trying to break traction? I know those things aren't indestructible, but surely it takes a lot more than 48k miles of normal driving to kill a transfer case.
Old Dec 21, 2007 | 08:11 PM
What is a transfer case?
Old Dec 21, 2007 | 08:36 PM
aquill1's Avatar
LINKY FOR YOU JASON>>>
Man that sucks having to replace a t case...thought they were sealed for life!
Old Dec 21, 2007 | 08:37 PM
is it expensive, should I worry about it at 55k?
Old Dec 22, 2007 | 09:42 AM
aquill1's Avatar
Don't do something stupid and you should be fine. Mine has just went over the 70k barrier the other day and all is well thus far...keep in mind if you get stuck in the car don't do anything stupid! I've heard that can screw them quite quickly!
Old Dec 23, 2007 | 04:43 PM
jag_genius's Avatar
i would get it changed ever 50 k
Old Dec 23, 2007 | 06:30 PM
aquill1's Avatar
Wasn't it because jag had never had a non-rwd platform so they wanted to keep it similar to that but add awd...
Old Dec 26, 2007 | 09:53 AM
xtyperick's Avatar
Bruce,
Early last week a new noise appeared. After running at Highway speeds for a few miles and coming to a stop, when I accelerate from stop there is a winding noise that revs w / the engine. It changes low to high with each gear change. To me it sounds like a power steering pump gone dry. I don't think it’s related to the engine accessories though because the sound goes away when I pop it out of gear and coast. It seems to need power on the drive train for it to occur.
They diagnosed it by me taking the tech for a HW run and he heard it. They thenran it up on the lift; listened underneathand said the transfer case was bad.
Unfortunately, the sound is still there so it’s going back in next week. Not sure if there is a bearing between the TC and the Tranny, but that is what it sounds like to me.
SpartanX,
Nooil on the garage floor where she sleeps. I usually catch stuff like vital fluids on the floor but that doesn’t mean it wasn’t leaking while driving. I really don't drive it hard…No snow here so I doubt I have ever broken the tires loose.
Maybe I didn't notice before on the old one, but it looks like the new transfer case has big fins on the bottom.
Old Dec 26, 2007 | 10:27 AM
SpartanX's Avatar
How much did that T-Case set you back? If I ever need one, and it's an arm and a leg, I doubt I'll get a new one. I'd just pick one up from a boneyard and call it a day.
Old Dec 26, 2007 | 10:42 AM
xtyperick's Avatar
Looks like the TC was ~ $2K and 4 hours to put it in. I still have 1400 miles left on my warranty so it was all No charge
Old Dec 26, 2007 | 06:59 PM
aquill1's Avatar
Bah humbug! That sucks so...hopefully you get feeling better...be careful to i hear pneumonia can take the best of us...my grandma had cancer and it was that which took her life not cancer itself. Man xtype rick 2k just for the transfer case! What a joke! That is crazy! Shoot you could get a totalled x type for around 5-10k and as long as the main components were good to go who cares seems like money better spent than 2k on just the part!
Old Dec 27, 2007 | 03:11 AM
peewee's Avatar
uho, mine is making a whining sound as well, i just equated it with the power steering fluid as well. Time to start examining my car. The noise is very subtle though. I have 45k miles on my 02 2.5
Old Dec 27, 2007 | 07:14 AM
I had the transfer case " whine " on mine some time ago, but comes n goes with only 28k miles on her now. Usually worst when cold although has been fine for a while now.
Its the ABS light and engine management light that are a worry at the moment for me. The new warranty I have taken out should kick in in around 3 weeks time so fingers crossed till then to save what will no doubt be a sizeable bill!
Jim
Old Dec 27, 2007 | 08:58 AM
xtyperick's Avatar
aquill1,
It was free...warranty covered everything including the 06 X loaner...FYI, for whatever reason, mine seemed quicker It only had ~ 18K miles but it was pretty beat up.
peewee,
I don't think the TC was bad as the sound is still there. I'll know more next week when it goes back in.
JimC64,
This sound really just started last week. Quite honestly, I'm glad it doesn't come and go as it would likely be harder for them to identify...and hopefully fix.
