Block heater, yes or no?
Old Jan 11, 2011 | 07:21 PM
Kevin 03 xtype s's Avatar
Default Block heater, yes or no?
Greetings from frozen central Alberta. What is the word on block heaters are the good to install or is it a bad idea? Thanks
Old Jan 11, 2011 | 08:08 PM
mohrd's Avatar
Where about in Central Alberta are you? I forgot.
I can confirm it's cold.
I can conform it's a good idea if you are parking outside tonight.
I can confirm you can have on on the X (I don't have one installed) but I'm not sure if it's a dealer only part. I would imagine so.
Old Jan 11, 2011 | 08:15 PM
Edmonton
Old Jan 11, 2011 | 08:23 PM
Mikey's Avatar
Hold on to your wallet- $230 plus installation at a dealer. Don't feel bad, it's $592. for an S-type.
I didn't even know my car had one till I was underneath doing an oil change and found the plug.
Old Jan 11, 2011 | 08:29 PM
If was not so cold I would have looked a little harder. Thanks for the help
Old Jan 12, 2011 | 01:29 PM
sidewalkman's Avatar
Crappy Tire had a model of a block heater that went into the heater hose, and had a small element and a recirc pump. So it kept the water pumping as long as you had you heater open and worked like a charm when I lived in Northern BC. It's universal, the regular block heaters replace a frost plug or something and are a friggen chore to install. This one took me 5 minutes.
Old Jan 12, 2011 | 07:59 PM
Thanks I will keep that in mind.
aode06
Jul 28, 2023 02:26 PM
xjrjag
Oct 12, 2015 03:16 PM
inactualis
Oct 2, 2015 11:13 AM
dieseldoc
Sep 28, 2015 01:17 PM
