Blue Tooth
Old Apr 7, 2015 | 02:48 AM
2006xtype's Avatar
Unhappy Blue Tooth
I can make and receive phone calls on my mobile through car system. I can hear person called/calling but they can't hear me. Sounds like it could be the mike or is there some fiendish trick I'm not aware of? TIA
Old Apr 11, 2015 | 03:14 PM
Rick_F's Avatar
Does your car have the voice activation system fitted? If yes, can you change radio stations, CD tracks etc with it? I think that uses the same mic, so if you can still change stations it would suggest the mic is fine and the problem is elsewhere.
Old Apr 11, 2015 | 08:06 PM
Bill400's Avatar
Default No VACM?
2006xtype,
If you have no VACM (voice activated control module) the microphone circuit must bypass that plug.
The VACM plug (PH2) is a 22way black connector located adjacent to the phone module in the left boot.
The bypass can be done using the voice activation shorting loop which is part number XR837852.
However, if you don’t have the shorting loop, it can be done simply using 22 ga copper (telephone) wire:
Use three 22 ga copper wires (green, white and yellow are recommended to maintain the color code), each 3-1/2” long, stripped 3/8” on each end. Fold each bare end back and crimp to form a 3/16” tab similar to the male plug pins. Insert the wires into the VACM plug:
Jumper Pin to Pin
Green 12 - 13
White 2 - 15
Yellow 1 - 3
The PH2, 22 way black connector is numbered on the back: 1, 11, 12, 22.
If you do a search "Bluetooth upgrade" on this site, you can see the detailed instructions with photos. Next time, you might want to search the site before starting a new thread.
best regards,
Bill
37driver
Oct 4, 2015 05:58 PM
JagBrian
Oct 1, 2015 12:52 AM
ziondio
Sep 29, 2015 01:58 PM
Wayne Enticott
Sep 29, 2015 08:55 AM
