bord indicator
Old Jul 8, 2017 | 01:38 AM
tibor's Avatar
Default bord indicator
Jaguar X type 2004
Everything works OK, but suddenly on bord it lights the ABS sign and then a lot f signs (battery,water...)the speed and rotation meter goes on zero and at the kilometers appears ligns only. The car works OK but this problems appears. What could be the problem and what to do?
Old Jul 8, 2017 | 04:02 AM
JagV8's Avatar
Bad power? Battery or connections etc.
Old Jul 8, 2017 | 08:23 AM
Thermo's Avatar
Veteran: Navy
tibor, could be a battery issue. But, this would normally also be associated with an engine that is running rough (from bad spark). It is possible you have an internal failure of the instrument cluster and that is what is causing things to look the way that they do.
ALLEN68
Oct 30, 2023 02:11 PM
lorant.bogath
17
Jan 29, 2017 05:44 PM
Elliebhall023
Dec 8, 2016 03:02 AM
jomo
Nov 15, 2016 03:30 PM
racerx82
Jul 18, 2007 09:50 PM
