Brake Lights Staying on
Old Dec 17, 2018 | 03:02 PM
Dell Gailey's Avatar
I did finally find a video of a "wagon" bulb replacement. Unfortunately it is the left side he works on.
Old Dec 17, 2018 | 03:33 PM
fontaine666's Avatar
https://youtu.be/WAVCk6uaayY
yeah so basically it means I can remove the bulbs without removing the assembly I think. So shall I just proceed by doing what was said but just removing bulbs like this?
thank you!
Old Dec 17, 2018 | 07:23 PM
Thermo's Avatar
Veteran: Navy
fontaine,as long as you can get to the bulbs, how you do it is not of concern. Get all the bulbs out and start putting them in one at a time. See what you come up with. Just make sure that you get them fully installed and not part way.
Old Dec 18, 2018 | 07:10 AM
Ok so i've had all of the bulbs out, connected one by one. The bulb that I mentioned above (pointing to in pic) is the one that turns the 3rd brake light on.
I reinstalled all bulbs properly and even tried the problem bulb in 2 directions and still the brake lights are on. Even with the problem bulb out the rear left brake light is still on.
Old Dec 19, 2018 | 07:41 AM
Thermo's Avatar
Veteran: Navy
fontaine, sounds like you have a bad back plane to the brake lights. Do some looking in your local wrecking yards to see if you can get a new tail light housing. That is about the only way that I can see you fixing this.
big woc
Jul 7, 2023 03:47 AM
platinummaker
Jan 10, 2018 08:20 PM
BradOKeefe
Jul 30, 2015 01:01 AM
Charlie Galea
Sep 4, 2012 01:23 PM
mafia_don
Oct 30, 2008 03:00 PM
