broken headlight
Old Jun 5, 2023 | 12:59 AM
HELP's Avatar
Default broken headlight
Hi, my headlight lens on my 04 jag are broken the replacement cost to much so,
I was wondering if there are any aftermarket headlights or from other cars that I can make a fit
dont mind if I have to trim some stuff, but I dont want it to look weird maybe abit better then the original
Old Jun 5, 2023 | 01:21 AM
h2o2steam's Avatar
I doubt there is anything suitably close, so probably best to try to stay with originals as it will be far less grief in the long run.
Perhaps you should be looking for something second hand from a breaker either in Canada or cast your net a bit further south.
Old Jun 5, 2023 | 12:17 PM
sov211's Avatar
Your car is an X-Type? (You give no information about the model - other than “04 Jag”). If so, the answer to your question is NO. The low and high beam headlamps are a single unit.
Old Jun 6, 2023 | 01:13 AM
HELP's Avatar
ok, would it be possiable to 3d print the lens with the same plastic PC?
Old Jun 6, 2023 | 01:48 AM
h2o2steam's Avatar
I can't imagine 3D printing would be able to give you the optical clarity required for creating a suitable lens, nor a acrylic material that would stand up to the application (heat and UV).
I recall reading a relatively recent thread where forum members were discussing a heating process to remove a damaged lens from the headlight cluster and replacing it with a decent lens from a donor light. See if you can search and find that thread and have a read first.
I still would recommend putting some feelers out to car wreckers to see what it out there in the second hand arena. You could check the classified ads on this site too and perhaps reach out to Dr Dome (forum member) who has been breaking down some X-Types for parts.
Be aware that you will probably encounter second hand headlight assemblies that have broken or brittle mounts and failed headlight tilt adjusting mechanisms, but if your clusters are still good structure wise and tilt adjustment gearing is not brittle and broken (or you pick up replacement tilt adjusting gear kits), then you are possibly just looking at picking up lights that have lenses you can try to remove and refit.
silvertonesx24
Jul 4, 2022 09:54 PM
talashek
Dec 24, 2013 11:19 AM
TOMALONIC
Feb 4, 2013 06:23 AM
carelm
Oct 6, 2009 01:16 PM
