A/C not kicking on right away.
2006 X type 3.0L V6. 136K
A/C used to kick in right away. Now I have to wait between 1 and 3 minutes to get cold air. I checked the compressor. It engages as soon as I push the A/C switch on but the gauges remain at static pressure ( about 100 PSI ). After 1 to 3 minutes, high pressure reaches nominal pressure, vacuum suction goes down at nominal pressure and the cold air flows in. I added some 134 just in case but didn't resolve the issue. Someone told me about a A/C bypass valve ( ? ).
I will welcome any suggestions.
Thank you.
Pierre.
Thank you.
Pierre.
