A/C problem, no cool air, replaced compressor and recharged
Old Jul 17, 2012 | 09:50 AM
rycymru's Avatar
Default A/C problem, no cool air, replaced compressor and recharged
2002 Jaguar X-Type 2.5L 5 Speed w/107k
Over the past year my a/c has slowly gotten worse. I checked the refrigerant and it read very high, mechanical probelm. It also sometimes worked when driving faster than 40. I recently read the TSB, ordered the O ring and completed the repair. I recharged the system and still a problem. I then got a compressor and replaced it. I then recharged the a/c again, this time it reads normal, but no cool a/c. I noticed that the passenger side is not cool, but it is not as hot as the driver side. I have checked the fan, and it comes on.
I really want to get this fixed asap. I am very mechanically inclined and work on cars as a hobby. I just think i am overlooking something and need a little help fully diagnosing the problem. I had a quote from a local place for $150 just to look at the car. I would prefer to get a little input from this forum first. Any help would be much appreciated.
Thanks,
Ryan
Old Jul 17, 2012 | 12:27 PM
Jac's Avatar
Jac
Check behind the cabin filter and make sure the flap is closed. If you can see the fan, then you'll have to reach in with a piece of stiff wire with a hook on the end of it and pull it shut. Mine was doing the same thing until I read on here about the door being stuck open.
Old Jul 17, 2012 | 12:43 PM
rycymru's Avatar
Thank you jac. Thanks for the tip of going through the cabin filter.
I started investigating more and it looks like the blend doors might be sticking, no fan change when i hit the recirculation button on and off.
I did notice that the far right vent on the passenger side, next to the door is the coolest blowing vent.
Old Jul 18, 2012 | 09:05 AM
Jac's Avatar
Jac
You might also want to block the flap from coming back open. Mine started getting a little warmer a few days later so I checked and the flap was opened again. I just used a piece of wood to wedge in there. Not sure if it's going to hurt anything by blocking it closed but at least I'll stay cool.
fast40driver
Apr 19, 2024 07:24 AM
Paradigm
Jun 15, 2019 05:59 AM
Rupesh
Mar 25, 2016 03:33 PM
TheWarlock
Sep 7, 2015 09:30 PM
johanasu
Sep 3, 2015 12:39 PM
