cat refurbish update
Old Feb 5, 2013 | 05:44 PM
Wahooesprit's Avatar
Default cat refurbish update
Might be too early but I have 500 miles on car and no 420/430 codes yet after I removed both cats and boiled them in citric acid powder solution for about 6-8 hours each...this is what I did in order:
new plugs
new IMT o rings
new air filter
new upper and lower plenum o rings
new throttle body o ring
new upstream/downstream O2 sensors
had 430 code again....then
cooked rear cat first, then front cat
put a can of BG 44K in gas tank to clean injectors
So far so good...76,000 miles in car
Old Feb 11, 2013 | 05:41 PM
up to 1000 miles and no check engine light yet...but the wife said the battery light flickered on a few times so I bought new cables from Jagbits and will put them on when they come in--thanks Thermo for the suggestion...battery tested fine and alternator too.
Old Feb 12, 2013 | 08:06 AM
tjandy's Avatar
I did the citric acid treatment to my front cat. I need to do it to the rear one, but getting it out looks like its not a lot of fun.
aode06
Jul 28, 2023 02:26 PM
Msteiner
May 16, 2016 12:19 AM
hkmcmast
Nov 29, 2015 06:56 AM
King Charles
Oct 16, 2015 01:25 AM
