catalytic converter troubleshoot
Old Jun 23, 2013 | 11:38 AM
Myjag2sexy's Avatar
Default catalytic converter troubleshoot
car started to misfire bank 2 (only when you gassed it) codes came up po302 , p1314, p1000. sounds like back pressure in the cat caused the misfire. so i pulled the cat out but have no way of telling if its good or not? the cat itself looks fine but how can i tell if it is clogged inside. i don't want to replace it until i am 100% sure this one is bad because these aren't cheap
Attached Thumbnails catalytic converter troubleshoot-2013-06-23_11.54.47.jpg   catalytic converter troubleshoot-2013-06-23_11.54.58.jpg
Old Jun 23, 2013 | 12:16 PM
clyons's Avatar
The following threads discuss how to clean a catalytic converter. Sounds like a cheap fix since they are already off.
https://www.jaguarforums.com/forum/x...nverter-64693/
https://www.jaguarforums.com/forum/x...ic-conv-64442/
Old Jun 30, 2013 | 10:15 PM
Kota62's Avatar
I realise that you've already pulled your cat, but what my mechanic had me do was pull the upper O2 sensor on the offending side, leave it plugged in electrically and go for a drive around the neighborhood. this allowed the back pressure to escape and my jag held 5,000 rpm without any trouble at all. we swapped the cat the next week and it did fix the misfire/restricted performance problem
HTHs
Gary
Old Jul 1, 2013 | 06:48 AM
Myjag2sexy's Avatar
Its very easy to remove that side cat. I took it out in ten minutes gutted it and put it back with no problem. It didn't affect my o2 sensors either. Beats spending 500 on a new one. I tried the cleaning method first but it didn't work
Old Jul 2, 2013 | 06:55 PM
Wahooesprit's Avatar
That looks like the front cat--mine was bad--the matrix was broken so I had to buy the $600 from Jagbits but the rear was throwing codes too--I cooked it on my outdoor grill for 8 hours with 2 lbs of citric acid in a 32 qt pot in January that was 16,000 miles ago and no codes--I now cook cats for all my friends haha
Old Jul 3, 2013 | 07:55 AM
Bruce in North Dakota's Avatar
From: That Rectangular Hole in the Consciousness of America
Originally Posted by Wahooesprit
"...I cooked it on my outdoor grill for 8 hours with 2 lbs of citric acid in a 32 qt pot in January that was 16,000 miles ago and no codes--I now cook cats for all my friends haha
Did you add 1 ounce of Sodium Chloride and 1 ounce of Piperine?
(Seems appropriate to me)
I have been to some crazy BBQ's, but your idea of a BBQ is the craziest!
Old Jul 3, 2013 | 08:23 AM
Brutal's Avatar
HTHs
Gary
or should have used a back pressure guage in the open port from the upstream 02. Or use a IR temp gun to check the body for overheating(plugged)
perezal
Dec 24, 2015 04:16 PM
Aus V8S
Nov 13, 2015 11:01 AM
hhv00586
Sep 18, 2015 08:59 AM
skadmiri1
Sep 9, 2015 11:27 AM
dragonfly777
Regional
Sep 8, 2015 01:39 PM
