center vibration!!!
Old May 15, 2012 | 10:41 PM
eric7216's Avatar
Default center vibration!!!
I have a 2002 x type 3.0 auto. Its been having a vibration issue for a while now and i have a few thoughts about it. First off. accelerating going between 30 and 40 in third gear their seems to be a vibration coming from the center of the car gets worse if you try to pick up speed faster while vibrating but doesnt vibrate much if taking it easy. I think its the drive shaft center support. Is that the same as the centering bearing?
Old May 16, 2012 | 12:02 AM
disguay's Avatar
sounds like a loose or really bad center support bearing. This bearing goes by many names.
driveshaft support bearing
propshaft bearing
and basically any combination of those words. As for changing the bearing, it is pretty simple. google "center support bearing jaguar x type" and buy one for around $150. Take off your driveshaft and take out the two bolts holding the bearing to the chassis. Take the old driveshaft with old bearing and new bearing to a shop and have them press the old one off and the new one on. Don't pay a dealer to screw you for $2k or more on this.
NTL1991
XJ40 ( XJ81 )
May 1, 2017 07:54 AM
Inspector
Oct 17, 2015 12:51 PM
adam699
Oct 13, 2015 05:53 PM
42Ajd
Sep 26, 2015 07:04 PM
