Centre Console non-functional + P1646 - ideas?
Old Apr 3, 2017 | 06:28 AM
csbeaumont's Avatar
Default Centre Console non-functional + P1646 - ideas?
Morning everyone,
Full story - driving home yesterday afternoon EML comes on, read the code - P1646 - Lambda sensor out - fair enough I think, bit annoying but not exactly unexpected on this car. If it helps, fault code shaded yellow.
This morning, turn car on, rear window a bit wet so turn heater on....nothing, only then that I realise the AC/climate is out, and the touchscreen is on the main menu and unresponsive to touch, clock is out (showing --:--) as is outside/climate temperature LCD screen. EML warning for P1646 now shaded red on my OBDII app.
Clearing the code within app brings everything back up and working, so there's not a problem with the console (as far as I can see) but yellow fault code reoccurs on engine shutdown and restart.
Would a lambda sensor really knock all of that stuff out? Or should I be looking for an electronics issue somewhere?
Thanks for your time.
Old Apr 3, 2017 | 11:25 AM
avern1's Avatar
I can't imagine a lamba sensor knocking out the power. I would be looking at load testing the battery. Removing and cleaning the battery cable connectors and also check the cables for signs off corrosion. It sounds like a loss of voltage.
Old Apr 4, 2017 | 03:05 AM
csbeaumont's Avatar
Brilliant, thanks, I'll start there.
Old Apr 5, 2017 | 06:15 AM
JagV8's Avatar
Bad battery, cabling, fuse blown, ...
Not caused by the O2 sensor, I suspect, but might be a common thing somewhere among that lot to explain all.
Old Apr 5, 2017 | 06:17 AM
csbeaumont's Avatar
Thanks, my suspicion too.
I'm guessing not the fuse though as clearing the ECU codes brought it back online instantly?
