Changing power steering fluid,
Old Dec 28, 2011 | 09:14 AM
harryc's Avatar
Default Changing power steering fluid,
Where can I find instructions on how to change the power steering fluid, and what type of fluid is required. Is it possible to slowly change the fluid out by continuously swapping new fluid for old fluid through the reservoir over the course of several days? I have known people to do that when they aren't comfortable getting under the car.
Old Dec 28, 2011 | 09:32 AM
Tony_H's Avatar
Disconnect the return line at the PS reservoir and connect to a container. Plug the reservoir inlet. Jack the front end up until the front wheels are off the ground. With the engine NOT running turn the steering wheel from stop to stop and add fluid to reservoir as you pump it out into the container. I used the latest version of Dexron.
Forcedair1
Sep 8, 2025 01:57 PM
PMKimpton
Aug 3, 2019 08:22 PM
sogood
Sep 15, 2015 07:35 AM
AL NZ
Sep 4, 2015 08:39 PM
pnwrs2000
Sep 3, 2015 11:55 AM
