closed loop
Old Dec 22, 2013 | 05:22 PM
nazoben777's Avatar
Default closed loop
Hi, sorry for the bad english... when i make a cold start in the morning the car on the OBD elm 327 shows closed loop, i've read that when engine starts first is in open loop then go to closed loop... my engine is popping from the manifold and run in 300rmp and shaking and when i swich of the MAF sensor it goes to 1000rpm and the engine works fine but in first 2min still popping?! Any ideas mates?
Old Dec 29, 2013 | 10:31 PM
daxter1987's Avatar
Try this...
jaghelp.com: That pesky rough idle
Old Dec 30, 2013 | 01:59 PM
nazoben777's Avatar
I cleared the maf sensor but... nothing, the car starts with big throttle and little vacuum shown on the obd scanner, could it be a vacuum leak?
Old Dec 31, 2013 | 12:17 PM
daxter1987's Avatar
That's easy to check with an OBD scanner:
  1. Look at the fuel trims with the engine at idle, are they close to zero? If they are not there is a problem.
  2. Looking at the trims, rev the engine to 2000 rpm. If the trims go to zero (not exactly zero but close to zero) then you have a vacuum leak.
To fix a vacuum leak on your x-type follow this link:
jaghelp.com: Jaguar X-type common vacuum leaks. P0171 and P0174
Old Jan 2, 2014 | 07:10 AM
nazoben777's Avatar
STFT1 and STFT2 show +25 when i start the engine... is that normal?
philwarner
28
Jul 11, 2017 10:21 AM
hkmcmast
Nov 29, 2015 06:56 AM
millertic
Sep 30, 2015 08:11 PM
