Clunking in Rear Solved
Old Aug 29, 2011 | 12:15 PM
WayCoolDaddio's Avatar
Default Clunking in Rear Solved
I have a 2006 X-Type 3.0 and have had an annoying clunking from the rear (mostly driver's side.) Has 78K on her. Had Shocks, struts, swaybar bushings, et. al. replaced all around. Still clunking.
Problem was the Parking Brake cables. A new Tech at my dealership tightened them and squirted grease into the channel that the cable runs through. No more noise! Nada!.
Tech said he does this for all X-types every 10K during the oil change.
Old Aug 29, 2011 | 02:08 PM
That could be useful info for the X typers.
Old Aug 29, 2011 | 03:27 PM
zoolander's Avatar
Default Rear clunk
This is exactly the kind of thing that you could waste 1000$ on and still not get it right!....I will try that myself and hopefully that takes care of it. Thanks for the post.
Old Aug 30, 2011 | 02:26 AM
Cadillac's Avatar
Thanks , appreciate the feedback
Happy driving
Old Aug 30, 2011 | 07:43 AM
KaysKat's Avatar
Ours had what my wife called a clunking. Took a look and found where the parking brake cable went through a bracket, just in front of what I call the trailing arm/lower control arm, the bushing had worn through, and the other side was missing. A couple inches of heater hose, some zip ties, and no more clunking!
Old Aug 30, 2011 | 08:51 AM
Thanks for the reply. That sounds like a great solution. zip-ties are a wonderful thing. My tech didn't mention anything about bad bushings. I'll have a look-see. I also found that the evaporators were loose and bouncing up against the floor. wrapped a peice of heat resistant pipe insulation around it to isolate the movement. Works like a charm.
Old Aug 30, 2011 | 11:40 AM
Lcgi's Avatar
OFF SPECIFIC TOPIC;
Howdy to all,
I have a similar annoyance - but mine appears to be coming from front underside of Vehicle ?
(Sounds like a plastic panel that is rattling - when car goes over road bumps)
So far, I've applied dabs of silicone to suspect panels that are fixed to or in contact with Steel Bodywork..... but that pesky rattle prevails !!
Anyone have a similar problem.... and fixed it ?
All help to locate and eliminate this problem - most appreciated.
Old Aug 30, 2011 | 12:13 PM
There are a couple of other possible culprits under there. Right behind the fuel tank is a small plastic box (evaporator). This can be loose and can bang up against the floor. I wrapped a piece of heat resistant Pipe Insulation around it making sure not to obscure the openings. Next is the heat shield around the fuel tank. It is pretty much like a roasting pan. This can also come loose and vibrate against the tank. You might be able to shim that with something heat resistant.
Old Aug 30, 2011 | 06:26 PM
Razkid's Avatar
LCGI, Using a rubber hammer and lightly hitting areas under the car can reveal loose components and panels.
Old Sep 10, 2011 | 11:43 AM
zoolander's Avatar
Hey WayCool...How & where did your tech shoot grease into the cable lines?...I took the wheels off and didn't see a spot where I could grease in...Thanks
Old Sep 15, 2011 | 10:55 AM
Unfortunately I did not see the exact location. As he explained it to me there is a channel that the cable runs through and it was into this channel that he applied the grease. So far 2k miles and no rattle. He did not replace any bushings that I am aware of. Should have asked to have it on a lift and see the location.
Old Sep 16, 2011 | 09:44 AM
Unhappy
Well I spoke too soon. It was a colder day yesterday (low 50F's) and the clunking has returned. Just over 2K miles since it was serviced. I am going to try KaysKat's solution of heater hose and zip-ties.
Old Sep 16, 2011 | 10:43 AM
Brutal's Avatar
Ive never heard those described as a clunk. More of a squeek as they more in/out of the dry plastic bushings. I swipe the cable with silicone paste and then slide the cables in/out to move the past in and stop the squeeking. An acurate description of a noise or problem is always worth alot when trying to solve issues.
Old Sep 19, 2011 | 08:09 AM
Thanks for the comment but; it is definitiely not a squeak. I've driven countless cars over the pat 30 years the noise in th rear is a clunking like something banging on the floor near the rear left Wheel Well. All rear suspension inspected and/or replaced. Need to get on a lift and poke around some more.
Old Sep 19, 2011 | 08:11 AM
pab's Avatar
pab
Just wondering, is your spare tire and jack screwed down tight?
Jaguar: Grace, Pace, and Space - Sir William Lyons
Old Sep 19, 2011 | 10:32 AM
Brutal's Avatar
Well then thats why i said that park brake cable is a squeek. ( ive fixed countless xtype"squeeks" doing this, and they were never descibed as a clunk by customers. Hense my questioning the noise description.....he didnt really "fix" your clunk issue by lubing that. Probobly putting the car in the air shifted something and "coincidentally" made the clunking stop. And or he applied lube in other areas too like control arms. I would look at the control arm bushing checking for excessive movement or rust around the bushing insert. Theyre known to go bad causing alignment issues and clunking. And personally if you can dulplicate it i would drive around with a set of wireless chassis ears to isolate the noise. Most all dealers and shops should have a kit, we do.
Old Sep 20, 2011 | 08:32 AM
Thanks for the guidance. I was cleaning the interior yesterday and engaged the parking brake to clean around it. Afterward the noise was gone again. It is not happening. I agree that the bushings squeak. I have had all the suspension in the rear, shocks, control arms, sway bars, bushings, everything re-done. Also the front, except the swaybar bushings because the bolts are rusted on and the shop said they would have to cut them off. So those squeak like a an old bed spring. But the noise in the back sounds like something knocking up under the floor or the wheel well. I have isolated the evaporator boxes which were rattling around. I have tried to tighen up the heat shields. (and the spare and jack are tight). I'll look into the chasis ears and see what elese I can find. It is frustrating as it comes and goes. Almost like something that alternately is knocked loose and then fixed again.
Old Sep 20, 2011 | 01:01 PM
zoolander's Avatar
Funny...I just tried that thinking that it might be the culprit but much to my dismay it was not.
Old Sep 22, 2011 | 08:11 AM
zoolander's Avatar
Brutal, a question if you don't mind...I just replaced the rear control arms that look like the little dog bones...the ones that are constantly referred to on this site as causing the inside of the tires to go bald....I still have some sort of clunk somewhere that I'm having trouble locating but I need to put tires on the car and I was wondering if you think it wold be a waste of money before I figure out the clunk? Thanks in advance!
Old Sep 22, 2011 | 08:19 AM
Brutal's Avatar
Not a waste, and only a waste if you havent fixed your alignment issue yet.
