Cocked Steering Wheel
Old Sep 15, 2011 | 08:04 AM
exrub's Avatar
Default Cocked Steering Wheel
I just had the 40K mile service done on my X-Type and also got two new tires with alignment. The car rides very nicely...with the exception of slight vibrations possibly slightly bent wheels. However, I noticed that I need to keep the steering wheel turned about 15 degrees to the left in order to keep the car straight. If I center the steering wheel, the car will veer to the right by about 3 to 5 degrees.
Anyone know if this would be an easy fix to true the steering?
Thanks!
Old Sep 15, 2011 | 08:09 AM
Having 2 new tyres and the alignment done is where your issue lies.
Usually when they do this, they have an impliment that keeps the steering wheel centred whilst they do their work ( obviously they haven't done this )
So when they've re aligned your steering the steering wheel has moved with it!
If it were me, I'd simply take it back and ask that they re align centering the steering wheel as they should have done in the first place.
Let us know how you get on
Old Sep 15, 2011 | 08:34 AM
joycesjag's Avatar
+1 with Jims advise. ^^^
Old Sep 15, 2011 | 11:14 AM
exrub's Avatar
Yeah; kinda what I was thunking but was giving'em the benefit of the doubt. I'm heading back there probably Saturday to have them re-align the steering.
Wish me luck!
Old Sep 17, 2011 | 02:43 AM
Best of luck.
Just a thought, but when you let go the steering wheel, does the car remain straight and true?
If not, then the alignment would again be suspect.
Old Sep 17, 2011 | 09:21 AM
exrub's Avatar
Best of luck.
Thanks, Translator!
Already thought of that and tested it; the car went straight.
Took it back yesterday, and they aligned the steering. It's still not exact but is tolerable. It only needs to be cocked about 3-5 degrees now which is a lot better than what it was. Holding the steering wheel at center will make the car veer to the right by about 1-2 degrees. I guess it can't be perfect.
H20boy
Dec 24, 2024 03:23 PM
PMKimpton
Aug 3, 2019 08:22 PM
RobertTheBloke
Sep 24, 2015 11:48 AM
Burdedw
Sep 12, 2015 10:39 AM
1964Daimler
Sep 9, 2015 11:28 AM
