Cold Air intake
Old May 31, 2011 | 01:47 PM
Adam Lueb's Avatar
Smile Cei
After many years of owning cars and trying various CEI, even the Dinan set up for a BMW I had, which along with required downloads, larger TB and CEI and muffler cost over $2K. Also, putting a CEI on a Porsche and Audi A6. I found that there marginally effective at best. I never got a great gain in HP or Fuel mileage. The HP came from dyno testing before and after. I use K&N replacement filters in my cars and they work just as well as the CEI I've had in the past. If you want more HP a CEI is not going to give you what you think your going to get. This is just my experience, perhaps yours will work well, but none that I had did much if anything at all for performance. They did sound nice at full throttle however, but how often does one go full throttle in the USA, not much. But this is only my experience, if you like it and it makes you feel the car is running better then have fun.
Old May 31, 2011 | 03:49 PM
budinsc's Avatar
guys, see my post today on the installing mina performance package thread. it explains why i chose the k&n filters instead of putting a cold air intake on my xk.
rock on, bud
Old May 31, 2011 | 05:40 PM
exexpat's Avatar
rock on, bud
You rock on, too, bud.
Old Jun 9, 2011 | 02:45 PM
sidewalkman's Avatar
Originally Posted by gragner66
Ill get my good camera out this weekend and take some good pics of the intake off the left side and look up the part#s.
what i used that you dont see is the flex tubing running from the spectre coupler (that is connected to 90* chrome piece) to another rubber coupler that is open beside the radiator. so its actually getting air from 3 places now the 2 stock intake holes and the one i made left of radiator
That couple part number for the left side of the air cleaner and anything below that would be appreciated, I haven't been able to find them. I have the setup waiting for me at Auto Zone to pick up identical to what Exexpat has. But I like the way yours is drawing cooler air into the filter as weel.
Old Jun 9, 2011 | 05:13 PM
Tec Nine's Avatar
kool
Old Jun 9, 2011 | 06:59 PM
gragner66's Avatar
ok here is the part#s
8147-piece that is connected to end of air filter(i used CF from dash to cover this)
8708-this is 4in straight piece
8706- chrome collar to connect pieces need 2 of them
8701-mounting kit i used 2 of these the 2nd i used at the first collar near the filter end to keep everything tight and not move
8698-90 degree tube
8771-black rubber piece with spectre printed on it
8741-black flex tube not seen
Ok now for what you cant see or know till you start working on this mod
that piece at end of filter is a ugly beige color i wrapped with CF i used on dash. it doesnt fit firm to filter but if you use 2nd bracket kit will make it very frim. you should have the collars you need to connect everything with out buying them extra. you only need about 1/4 of the flex tube to run out the front. i used the rubber piece that comes with flex tube on end where it is open beside the radiator. you will have to cut this with an xacto knife once it is connected when done it should be a tad bit bigger than the stock intake ports. you will need a bracket to mount black box(look at purple zip tie in my pic) i used a piece of real CF. i used 2 black hex bolts to replace the stock silver bolts. handle the rubber peice with SPECTRE printed on it carefully it comes of easily. i also painted bracket used on collar at end of filter to keep from standing out
hope this helps ill try to get better pics this weekend kids been sick and didnt get any yet
Old Jun 9, 2011 | 09:05 PM
exexpat's Avatar
Just wanted to say that you're the man. CF dash treatment, filter, front spoiler, exhaust and all. You've done a ton of work and it shows.
That is all.
Old Jun 10, 2011 | 07:10 AM
  #28
Adam Lueb's Avatar
I congratulate you for the work you did. You are a "car guy." I hope the CAI works for you.
Old Jun 10, 2011 | 10:52 AM
Tony_H's Avatar
Why would you want to do this? The stock X Type already picks up cold air ahead of the rad so you're not going to make it significantly better. You can put in a low resistance filter (k&n), but replumbing doesn't make any performance sense to me.
Old Jun 10, 2011 | 10:56 AM
  #30
southernjag's Avatar
Mostly all about looks.
Old Jun 10, 2011 | 03:55 PM
  #31
And the sound, an open element filter just sounds cool. Really throaty, as for air, the jaguar air box system is fairly restrictive with only the 2 snorkel things for fresh air.
Old Jun 10, 2011 | 05:25 PM
  #32
Tony_H's Avatar
Ah yes, noise...just drill a few holes in your mufflers.
More seriously, when I look at the pictures, how does this setup work? It looks like the air flows left to right through the center of the filter without ever going through the filter element.
Old Jun 10, 2011 | 08:07 PM
  #33
exexpat's Avatar
We did it for extreme performance gains and track prep. That's all.
P.S. Drilling holes in the muffler is an awesome idea, no idea why I didn't think of that sooner.
Old Jun 10, 2011 | 09:15 PM
  #34
gragner66's Avatar
Ok first thnx for the compliment exepat, 2nd I did this mostly for looks plus it does sound really good with the mina exhaust these cars aren't meant for hi performance sad to say
Old Jun 11, 2011 | 07:51 AM
  #35
Adam Lueb's Avatar
Smile Cai
Your correct the X Type for a passenger car has a well thought out intake system. I don't see how a CAI could pick up any more cold air. I use a K&N myself and have for many, many years in my car and for street driving they do the job.
Old Jun 12, 2011 | 12:24 PM
  #36
dalecan's Avatar
You should try to set-up some type of shielding to prevent heat soak.
Old Jun 13, 2011 | 11:00 AM
  #37
Adam Lueb's Avatar
Cool Cai
Yes without a heat shield in back of the filter, you are kinda defeating the whole purpose of a COLD air intake. All the one I fooled with had heat shields of some sort.
As someone and I said the intake in these cars are about as good as your going to get as far as cool air intake. Years ago a friend of mine took Dynamat
and wrapped his air box and most of the intake pipe with another flexible heat repelling material, didn't do much. I still say a replacement K&N filter will produce the same results. Dyno the car and see how much HP you have gained, if it is more than 5HP I will be surprised. If you had a supercharger or turbo charger, then there might be some gain in HP and torque and noise.
Old Jun 13, 2011 | 03:37 PM
  #38
exexpat's Avatar
If you are purely into augmenting performance, don't modify your X-Type with anything cosmetically appealing.
If performance is what you are after, strip it of its interior, replace glass with lexan wherever possible, have carbon fiber replacements made for the hood, fenders and trunklid, take out the AC compressor and other non-essential engine components, move the battery to the trunk, get some forged 16 or 17" wheels with track tires. The end result will look ugly, but should get you around a track faster than stock.
Old Jun 13, 2011 | 04:26 PM
  #39
Also, didtch the expensive leather for some racing seats. All the power options and AC have to go., While we're at it just scrap the whole rear seat, the spare tire, the radio, get an aluminum rad.
Face it, we're driving a semi sport semi luxury car. I'm adding the CAI (actually HAI) simply because it looks cool. I would have gone with an M3 or an AMG if I was looking for dazzling performance.
Old Jun 13, 2011 | 06:51 PM
  #40
vai1953's Avatar
Nice, what was the total cost of the refit?
