Consistent old bed spring noise coming from front of 2003 X-Type
Old Apr 7, 2013 | 03:02 PM
Humy's Avatar
Default Consistent old bed spring noise coming from front of 2003 X-Type
Dudes,
I am hearing an old bed spring noise coming from the front of the X. Weird thing is, you can't hear it when you first start driving. Then as I go about 10 miles or so, it starts up and you can hear it over every little bump. Even when I stop, you hear it as the front end goes up after the cat comes to a full stop. I sprayed white lithium grease over the shocks and springs, didn't help. Is this a common issue, any ideas? I am not feeling any difference in handling.
Old Apr 14, 2013 | 09:28 PM
Humy's Avatar
So weird, no noise when I first start driving. Starts after about 10 minutes. Bump
Old Apr 15, 2013 | 07:25 AM
Thermo's Avatar
Veteran: Navy
HUmy, I would try applying a little bit of grease to the lower A-arm bushings on the front end. From what you are describing, that is your next most likely source of the noise. We can then take it from there.
BrentGardner
29
Dec 16, 2024 12:13 AM
rvdz
Dec 7, 2019 06:42 AM
Fraser Mitchell
Oct 1, 2015 04:06 AM
Sshenton1975
Aug 30, 2015 09:29 AM
Mr.B
Aug 28, 2015 02:14 AM
