Coolant concerns~
Old Feb 6, 2018 | 12:22 AM
Harry Peter Rose's Avatar
Default Coolant concerns~
losing around an inch a month from coolant reservoir...cannot see any leak ...more than normal smoke/steam from exhaust I think..any suggestions?
Old Feb 6, 2018 | 01:23 AM
Robman25's Avatar
Take it to a radiator shop and ask them to carry out a pressure test and also a TK test, this tests for combustion gases in the water.
Old Feb 6, 2018 | 08:38 AM
Alfadude's Avatar
How is the performance of the car? Notice any difference? Check the oil to make sure it is not milky to rule out a head gasket.
Have you checked by the water pump and the thermostat housing? Any collant drops ever on the ground? If so, where?
Old Feb 6, 2018 | 01:07 PM
avern1's Avatar
A frequent point of leakage that doesn't show any water staining is the upper radiator hose it consists of 2 hoses and a plastic pipe that tees off down to the thermostat. It will crack across the top and open under pressure and at temperature and won't leak when engine is cool.
The constant heating and cooling of the plastic cracks it. If you find it bad by the complete upper hose assembly. It will come with new hoses, plastic pipes and a new thermostat. I think mine was about $98.00 from Jagbits or SNG Barratt.
Old Feb 6, 2018 | 02:23 PM
NORMAL PERFORMANCE /OIL LOOKS GOOD/ NO COOLANT DROPS
shall look again and perhaps pressure test....thanks to all!
Old Feb 6, 2018 | 04:23 PM
Alfadude's Avatar
And the most obvious, but have to ask: You do not see any pooling at the bottom of the coolant expansion taak and/or a crack by the upper nipple fitting of the tank, did you?
Old Feb 6, 2018 | 06:55 PM
no sign of pooling/leaking
ruladiesman217
Dec 8, 2008 12:21 AM
whatyathink
Apr 29, 2008 02:15 PM
Mark35o
Apr 21, 2008 09:01 AM
Mark35o
Apr 11, 2008 06:19 PM
peewee
Jul 12, 2007 07:03 PM
