Coolant level sensor
Old Jun 25, 2017 | 07:53 PM
Man on the hill's Avatar
Default Coolant level sensor
Does the x type normally have a coolant level sensor fitted in the expansion/header tank ?
My car has the wiring plug, and the expansion tank has the moulding to take a sensor, but no sensor is fitted.
Thanks,
Paul.
Old Jun 25, 2017 | 10:46 PM
Dell Gailey's Avatar
https://www.jaguarforums.com/forum/x...-sensor-71865/
Old Jun 26, 2017 | 08:47 AM
avern1's Avatar
The X-Type does not have a coolant level sensor in the expansion tank. The expansion tank has visible coolant level lines imprinted on the tank.
If the cable you see near the tank is a 2 conductor plug and doesn't appear to have a home then it is the battery isolator connection that was used on the car when shipped from the factory.
You will find a nub at the bottom of the battery box. That is where that wire is plugged in. It is just a holder to keep it form floating around loose.
