Coolant reservoir hose-again
Old Jan 21, 2015 | 02:33 PM
Spikepaga's Avatar
Default Coolant reservoir hose-again
Hello everyone!
I changed this hose 6 months ago. Now it's spraying coolant all over the car again, in considerable amounts right where the T clamps to the other hose. Its Also dripping At the reservoir clamp. Tightening has not helped:
Is this happening because it's an aftermarket hose?
Always coolanr leaks with this car! Driving me nuts
Old Jan 22, 2015 | 09:54 AM
hammerma68's Avatar
Just a hunch, but maybe new hose clamps would help. Is there any oil in coolent or coolent in oil? Maybe head gasket or ? pressurizes coolant system?
Old Jan 22, 2015 | 10:20 AM
Spikepaga's Avatar
Thanks for your reply.
I tried new clamps and that has not helped.,
Not too sure how a faulty head gasket would cause the hose to spray coolant at the joint though.
Thoughts?
Old Feb 8, 2015 | 11:48 PM
Ashlita's Avatar
Did you ever get this fixed? Mine is doing the same!!
Old Feb 9, 2015 | 07:39 AM
mrplow58's Avatar
Try changing the clamps, and a full coolant change. You may also have a faulty coolant reservoir cap, that is not releasing pressure, or a T fitting with a small crack....Be cool......Mike
Old Feb 9, 2015 | 09:37 PM
Spikepaga's Avatar
Yes, the problem was the cheap aftermarket house::
https://www.jaguarforums.com/forum/x...months-135444/
Poet
Feb 7, 2025 02:18 PM
MrWhite
19
Jun 14, 2022 07:49 PM
X308XJR
May 20, 2019 06:50 PM
Gregory Neil O'Rear
Sep 29, 2015 09:52 AM
