Coolant temperature
Old Apr 18, 2018 | 04:12 AM
jaguarxjordan's Avatar
Default Coolant temperature
Hello,
a quesion of what is the high- normal coolant temperature would be with AC on , and AC off in celcuis?
im using a liqui Moli 1:1 .
thanks in advance.
Old Apr 18, 2018 | 08:17 AM
avern1's Avatar
Normal operating range depending on the thermostat is 87 to 90 C.
The fan controller causes both fans to operate on high at 100 C.
The ECU operates both fans whenever the air conditioner is ON.
Old Apr 18, 2018 | 04:38 PM
Dell Gailey's Avatar
Here's a shot of torque log of some of mine while driving. Log is several pages long on a 150 mile drive w/changes in elevation from 4,200 - 5,900 - 4,500 feet pulling a load up and near coasting down (engine brake on cruise).
Old Apr 19, 2018 | 06:27 AM
Fruitful information, thanks for
both of you.
Old Apr 21, 2018 | 02:18 AM
Today's Reading as follows since i have scangauge:
AC on : coolant temperature was 101 Celcuis .
AC off : coolant temperature was around 97 C.
is it ok or overheating?
Note that weather temperature was around 30 C.
Thanks for help.
Old Apr 21, 2018 | 09:31 AM
avern1's Avatar
Not knowing what driving conditions were. Stop and go around town, or open road. It seems to be warmer than I would like but not to the point of overheating, You might want to flush the cooling system and change the thermostat. The existing thermostat may not be opening fully.
You might also want to try to wash out the area between the A/C condenser and radiator. You should be running around 90 C. You are a little warm but not dangerously hot.
Old Apr 21, 2018 | 06:48 PM
dh53's Avatar
Lab grade temperature measuring systems that cost under several hundred dollars are typically good to +/- 2 degrees C. You are looking at data from a sensor that costs maybe $2 to produce, has to work reasonably well no matter the date or location or brand of manufacture, with who knows what changes in the signal due to oxidation at the connections over time... Do not get hung up on a few degrees C.
jsjunky
Jul 10, 2024 12:26 AM
chattiml
Dec 16, 2019 08:52 PM
georgia boy
Jan 26, 2011 08:47 AM
Atweis
Sep 9, 2010 12:34 PM
rcgrcg1
Apr 21, 2009 05:09 PM
