Crazy rear steering on exit ramps...
Old Nov 18, 2014 | 05:38 PM
wesmc's Avatar
Default Crazy rear steering on exit ramps...
2003 x-type 2.5. When I take an exit ramp with any speed the rear suddenly feels very loose and acts like it wants to go to the outside of the curve. I remember seeing multiple posts on this but can't locate them using search....any help would be appreciated?
Seems like it would be a control arm issue. Manually prying on them they seem fine but I'd be glad to replace them if they are the typical culprit.
Old Nov 18, 2014 | 06:20 PM
Thermo's Avatar
Veteran: Navy
Wes, your lower/forward (the small arm) on each side of the rear suspension need to be swapped out. The bushings have some extra play in them and it is allowing the rear suspension to move a little resulting in the feeling that you are experiencing. The arms are about $100 each and are easy to install (remove 2 bolts, remove the arm, reverse for install). Don't forget to get an alignment afterwards. You will want to get this fixed fairly soon, otherwise you can anticipate some accelerated wear on the inside edge of the rear tires.
Any questions, let me know.
Old Nov 18, 2014 | 08:17 PM
wesmc's Avatar
Thanks...got em ordered.
H20boy
Dec 24, 2024 03:23 PM
rusty37
Apr 5, 2020 07:40 PM
kevinl
Oct 31, 2019 06:15 PM
PMKimpton
Aug 3, 2019 08:22 PM
AL NZ
Sep 4, 2015 08:39 PM
