Creaking rear near side
Old Mar 2, 2014 | 03:02 PM
ropetec007's Avatar
Default Creaking rear near side
Hi all,
When driving my x type saloon 3.0 auto 2003 there is a fair bit of creaking coming from the rear near side when going over bumps, however this stops with people in the back...
Any ideas?
Old Mar 3, 2014 | 04:20 AM
Thermo's Avatar
Veteran: Navy
ropetec, it is possible that your rear spring has shifted slightly and it is rubbing against the cup that the spring sits in when the car is unloaded. BUt, with some weight, it collapses that coil and therefore you don't have any movement then. Otherwise, you will need to remove the wheel and see if you can spot something going on.
Another thing to ponder is that the sway bar supports for the main bar will tend to dry out and it is possible that those are the source of your squeak. You can spray the rubber bushings with some WD-40 and see if that corrects your squeak.
Old Mar 3, 2014 | 03:00 PM
ropetec007's Avatar
Hi Thermo,
Many thanks for your help, much appreciated.
mbergen
Oct 23, 2019 10:26 PM
PMKimpton
Aug 3, 2019 08:22 PM
KarimPA
Sep 12, 2015 08:15 AM
Tar
Sep 6, 2015 11:24 AM
prettydaim
Sep 4, 2015 09:13 AM
