Cruise control stays on
Old Dec 12, 2016 | 04:29 AM
Jaymo's Avatar
Default Cruise control stays on
Jaguar X Se D 2ltr. 2004. In UK
Had this a few month but know little about them .
The cruise control seems to be staying on and I have to keep cancelling it almost every time I move. I don't remember it being like that before. Has anyone had that or know how I can stop this. I don't need the cruise control at Al as I only drive local and it's all stop start traffic. Any tips or hints appreciated for a newbie.
Old Dec 12, 2016 | 02:20 PM
Thermo's Avatar
Veteran: Navy
Jaymo, sounds like the SET button on the steering wheel is stuck slightly depressed and it is causing the cruise to engage.
Old Dec 13, 2016 | 05:12 AM
Jaymo's Avatar
Chris thnks for that tip. Any idea how I could solve that. Is it as simple as a spray of WD40 or has steering panel got to come of. Any advice appreciated.
Old Dec 13, 2016 | 08:07 AM
avern1's Avatar
I wouldn't recommend WD-40 as you will probably gum it up more. Find a can of Electrical Contact Cleaner. It is available at most auto parts stores. I would spray it down lightly and exercise it on and off a few times.
If that doesn't work out for you the switch is probably defective and will need to be replaced.
Old Dec 13, 2016 | 09:09 AM
Jaymo's Avatar
Thanks Vern, I will give that a try next week when I'm off work.
