Cruise not available
Old Nov 5, 2020 | 06:01 PM
Peterwilson's Avatar
Default Cruise not available
MAF X Type. I’ve just changed the spark plugs on my x type and I had to remove the MAF sensor because someone had superglued the plug together due to broken catch, etc etc…
Anyway, when screwing the sensor back in, I accidentally touched the positive battery terminal with the screwdriver!!!!!!! Now I’ve got the famous cruise not available on the dash, an orange jelly bean and crap engine performance. I’ve ordered another sensor for $29AU and hoping I haven’t done any more damage. BTW the spark plugs badly needed changing.
Old Nov 6, 2020 | 07:06 AM
TonyJ1977's Avatar
I would go thru your fuse box’s with a fine tooth comb and check every single fuse to make sure none blew first and then run or have the codes ran and see what codes it has and post them here and don’t leave any of them out and someone might be able to help you better. Also make sure that all wires and sensors are plugged back up. The one on the throttle body is one that’s known for allot of ppl to forget plugging back up and it alone will cause all the problems you described
Old Nov 8, 2020 | 06:29 PM
Default Codes front Cruise not available
Hi and thanks for your reply. The only code I’m getting is P 103.
Still waiting for the MAF sensor
aceler8
Oct 1, 2020 07:45 AM
santacruzmg
Jun 10, 2016 01:48 PM
Harry Dredge
May 1, 2016 07:23 PM
Xander Winther
Feb 23, 2016 03:45 PM
jaguarloso
Aug 28, 2014 12:14 PM
