CV Axle
Old May 15, 2017 | 09:12 AM
THantzar's Avatar
Default CV Axle
Can anyone give me advice or suggestions on replacing the CV axle on a 2003 X-Type AWD? I THINK mine failed. Car has 153,000 on it. Car will not move when put in gear and I get a clicking sound when it's put in park.
Old May 15, 2017 | 09:15 AM
Welcome to the forum THantzar,
I've moved your question from US Lower Atlantic Region to X-Type forum. This is the place to post technical questions about your model.
Old May 15, 2017 | 12:41 PM
avern1's Avatar
In your post you state that you get no movement when you put the gear selector in reverse or drive. Correct?
It is doubtful that you have a bad CV joint. A broken or worn one would create a lot of noise but would not stop the car from moving forward or backward.
We are going to need some additional info to be of assistance.
1. Is there any warnings on the dash screen?
2. Have you had the OBD scanned for any codes?
3. Have you had any recent work or maintenance performed?
4. Did you have any unusual noises or performance issues before this occurrence.
5. Lastly has the vehicle been driven through heavy rains or sat out in heavy rains.
6. Have you load tested and fully charged the battery, are the battery connections clean and tight?
Many problems on the X-Type are the result of a weak battery. The engine and the transmission are all electronically controlled.
For a starting point you can check the wiring to the transmission and the cable from the shift lever to the transmission rotary switch for damage.
Old May 15, 2017 | 01:59 PM
THantzar's Avatar
Thanks, Vern, for your response.
1) I did eventually get a "Gearbox Fault" message.
2) The only thing a scan showed was the oxygen sensor.
3) No work done while I've owned it (3 weeks). The previous owner had the left CV joint replaced.
4) I did notice that the steering wheel shimmied and it got progressively worse, at low and high (55mph) speeds. The first time I heard a sound - a clicking sound - was when I made a left turn into the parking lot.
Now - since I started writing this my mechanic called. Said it was the right front axle....with after-market price and labor....$450. I trust this mechanic implicitly. Thoughts?
Old May 15, 2017 | 03:25 PM
avern1's Avatar
Ok the CV joint definitely sounds like a replacement is needed. But as i said it want stop the car from moving. You will need to have some one capable of reading the transmission codes. Most OBD Code readers only do the Engine Management System and not the various other modules. Once you get the codes post them and we can help further.
By the way cost for replacement sounds pretty reasonable.
