Damaged tyre bead-is it safe to drive?
Old Dec 21, 2013 | 04:56 PM
yeeran's Avatar
Default Damaged tyre bead-is it safe to drive?
Hi all,
Just found the bead of front driver side tyre was damaged, maybe from curbing. I will have a long trip to NYC tomorrow (>200 miles). So please let me know if it is safe to drive with such a damaged bead. I think I have already put more than 1000 miles on the car since this damage. Thanks!
Ran
Attached Thumbnails Damaged tyre bead-is it safe to drive?-img_20131221_170831_155.jpg
Old Dec 21, 2013 | 11:10 PM
My advice would be to get it changed as soon as is practical.
I wouldn't want to be covering 200 miles+ with that, the tyre wall will likey be weakened and at highway speeds could make it prone to blow out.
It is of course your car, your life and your choice.
Good luck
Old Dec 22, 2013 | 08:55 AM
Thermo's Avatar
Veteran: Navy
yeeran, like Jim says, it should be replaced at the earliest possible time. But, based on the fact that you have already driven 1,000 miles with that, you can probably make the trip home and deal with it there. But, every mile you drive, you are raising your odds of a failure. If you are going to drive home, I would try and keep the speeds down as much as practical to minimize the amount of heat build up and also if the tire does let go, it will be that much easier to regain control.
Old Dec 22, 2013 | 03:52 PM
MarkC's Avatar
That looks cosmetic gouge in the rubber "bump" the is supposed to protect the lip of the wheel. Any cord showing underneath?
Forcedair1
Sep 8, 2025 01:57 PM
PMKimpton
Aug 3, 2019 08:22 PM
Rlover
Mar 30, 2016 10:04 PM
Dicque
Sep 19, 2015 12:53 PM
Xkr x100
Sep 6, 2015 08:50 AM
