Diesel Injectors Again
Old Feb 14, 2015 | 10:10 AM
honda90's Avatar
Default Diesel Injectors Again
Today I have done a leak off test on my injectors, I have already used a bosch ESI[tronic] diagnostic from work which told my injector 1 was out of spec all the rest were showing a green result. Injector 1 leak off was over 130 ml injector 2 60 ml injector 3 95 ml injector 4 60 ml i used the Delphi recommended way of doing the leak off test below.
2 minutes running at idle followed by
30 seconds with the accelerator held at 3800 rpm followed by
30 seconds at idle followed by
30 seconds at idle.
do you think I will get away with changing injector 1 & 3, or should I do them all, the car has done 130000 miles. A link with pictures of the bottles showing the leaked off diesel is below.
https://www.flickr.com/photos/104546...7650401767460/
Delta66
Oct 4, 2015 05:40 PM
jospolice
Oct 2, 2015 07:16 PM
Jaguar Forums Editor
Jaguar Press release
Sep 30, 2015 03:08 PM
SD96XJ6L
Sep 25, 2015 10:53 PM
