dip stick
Old Dec 7, 2009 | 10:12 PM
Jessy's Avatar
Default dip stick
soooooooo ......yeaaa there aint a dip stick for the tranny fluid eh? how do i add tranny fluid then? my dad just went nutts haha after driving my xtype because she kept jerken when he steped off the gas....ud think that jag would make a friggan dip stick for the tranny over the years but i dont know what they were thinking with this one. Does anybody have a general quote for a tranny fluid/drain change? aswell with general quote on a rear diff?
Old Dec 8, 2009 | 02:35 PM
sidewalkman's Avatar
It's supposed to be a 'sealed unit'. But under the battery on the left side there is a small rubber plug, then on the left side under where the linkage hooks in there is a recessed allen bolt. Undo the allen bolt and fill till the fluid comes out the level hole.
I think there is a drain hole under the tranny too. Jag usually drops the pan to check the magnet and change the fluid.
Old Dec 8, 2009 | 04:00 PM
Thermo's Avatar
Veteran: Navy
Per the JTIS, you are supposed to check the fluid level with the motor running for reference. Car in PARK, engine running, sitting level. Then when you go to add fluid, you should have the engine off and the level checking plug installed. Not sure how much the level changes with the motor running and not.
Old Dec 8, 2009 | 07:29 PM
Colt's Avatar
Banned
Engine must be running while in park at about 104 degrees F fluid temp, to check fluid level.
Old Dec 10, 2009 | 01:10 PM
JagXV6's Avatar
Maybe if Jag made the tranny in the X Type they would have but it is made by JATCO--Japanese Automatic Transmission Company--not to metion the whole car is pretty much a FORD anyway! Just a "Gussied Up" Taurus--as one guy I know called it!
tlynch
Dec 31, 2020 01:58 PM
Chuck Schexnayder
33
Oct 24, 2015 10:20 PM
adam699
Oct 13, 2015 05:53 PM
goingjag
Sep 30, 2015 09:27 PM
pnwrs2000
Sep 30, 2015 01:56 PM
