Does the bolt go through the pan?
Old Feb 24, 2009 | 04:47 PM
michaelnv's Avatar
Default Does the bolt go through the pan?
So I've got a few drops of oil on the garage floor. I check for leaks and of course the bottom of the engine is oily. But the drain plug is wet (never been changed) and theres a bracket to the right of the drain plug attached to the pan with a bolt going into the pan that is also wet. Does anyone know if this bolt go all the way through?
I cleaned everything off but do not see where it could be leaking.
I am coming due for an oil change so I'll replace the drain plug.
Any suggestions on what else would be leaking?
Old Feb 24, 2009 | 05:42 PM
racerx82's Avatar
Pictures would help...there's about 20 other places the oil can be coming from.....sorry
Old Feb 24, 2009 | 06:22 PM
The Chris X's Avatar
Are you talking about the bolt holding the POS scoop to the bottom of the pan?
Got $5 on the pan gasket if it's not obvious anywhere else.
Old Feb 24, 2009 | 07:55 PM
jag_genius's Avatar
It doesnt drain from that bolt . It just holds the bracket .you need an oil pan gasket probably
Old Feb 24, 2009 | 09:51 PM
Brutal's Avatar
Ill put $10 on pan gasket too
Old Feb 26, 2009 | 06:42 PM
racerx82's Avatar
i'll do 10.01 on oil pan gasket
Old Feb 26, 2009 | 09:24 PM
Brutal's Avatar
Ill raise your $10.01 to $15.80 and call
Old Feb 27, 2009 | 06:25 AM
In this economy - you guys are brave!
SD96XJ6L
Dec 27, 2025 09:58 PM
Johncy2000
Oct 2, 2015 01:05 AM
baskervillema
Oct 1, 2015 06:43 PM
dmatthewman
Sep 30, 2015 10:10 AM
