door auto locking question?
Old Jul 1, 2013 | 05:30 AM
M9G's Avatar
M9G
Default door auto locking question?
Hi
Is there a way of disabling the door autolock fumction?
Old Jul 1, 2013 | 06:31 AM
jimbov8's Avatar
Not completely sure but I think that is a dealer programmable option, so your local indy might be an option for cost.
Old Jul 1, 2013 | 11:59 AM
mjtemple's Avatar
Taken from the UK forum.
1. Turn the ignition to the first point but don't start the engine.
2. Lock the doors by pushing in the short chrome lever above the drivers door handle, then pull the lever to unlock the doors. Repeat this sequence twice more.
3. Turn the ignition off and leave it off.
4. Lock the doors by pushing in the short lever by the handle, then pull the lever to unlock the doors. Repeat this sequence twice more.
5. Turn on the ignition again but don't start the engine. A ping should be heard.
6. Lock the door by pushing the lever by the handle, and then pull the lever to unlock the doors. A final double ping should be heard to indicate auto locking is enabled. If you've disabled the feature another ping will be heard when you drive off and exceed 4mph.
Not sure if it works for other market cars.
Old Jul 1, 2013 | 12:54 PM
M9G's Avatar
M9G
BRILLIANT!!!!!! it worked and yes mine is in the UK
if you dont mind i just want to add a couple of things as i got caught out on them - its not altering what you put its just adding
1. Turn the ignition on so dash lights come on but don't start the engine.
2. Lock the doors by pushing in the short chrome lever above the drivers door handle, then pull the short or long lever to unlock the doors. Repeat this sequence twice more.
4. Lock the doors by pushing in the short lever by the handle, then pull the short or long lever to unlock the doors. Repeat this sequence twice more.
5. Turn on the ignition again so dash lights are on but don't start the engine. (A ping should be heard)
6. Lock the door by pushing the short lever by the handle, and then pull the short or long lever to unlock the doors. STOP!!!!!! thats auto-lock disabled
If your wanting to re-enable auto-lock you at this point Lock the doors by pushing in the short lever by the handle, then pull the short or long lever to unlock the doors and a final double ping should be heard to indicate auto locking is enabled.
DOH!!!!!!! just seen this in the HOW-TO's and i was blimmin looking for it in there, must be blind
99xk8guy
Sep 29, 2025 10:51 PM
Wolfy
May 28, 2024 08:06 AM
XJsc-guy
Nov 23, 2015 01:56 PM
Dz1rfj
Sep 16, 2015 03:44 PM
pnwrs2000
Sep 3, 2015 11:55 AM
