door locks keep locking,interior lights flashing
Old Mar 17, 2011 | 10:30 PM
Bob.H's Avatar
Question door locks keep locking,interior lights flashing
HI GUYS, first time here, I have a 03, x-type , Canadian jag, 2.5 the problem is when I put her in drive, by time I get to the bottom of the driveway ,the door locks keep locking, the interior light flashes and the door open icon on the dash blinks, all for about 5 seconds and this can go on again when I hit the brakes , or even use the wipers any help on this one would be greatly appreciated thanks Bob
Old Mar 18, 2011 | 01:39 PM
IrishXtype's Avatar
try this..if u have key fob, go unlock all doors by hand, use key fob to relock, and set alarm...then use switch blade to enter driver's side door. take a short trip and see what happens.
idea 2..check back child saftey locks,make sure there turned all the way to one posistion and not stuck in between.
idea 3.. Our door locks are on a vacume system, so if the first 2 dont work maybe u have a leak somewhere that is making the locks ,unlock while driving,,then as it should over 10mph i think the saftey comp tries to lock the doors
Old Mar 18, 2011 | 02:25 PM
Bob.H's Avatar
THANK YOU, I tried the first 2 with no luck ,so i'll hunt down a leak
Old Mar 18, 2011 | 04:13 PM
Glendoramike's Avatar
Usually this happens because the door ajar switch is dirty or wet and it doesn't work right. I always got them fixed by spraying them if WD-40 and working them. Most of the time this fixes it. Your switch works by hooking the ground to the control module. Check grounds and wiring before buying the big buck items. Your switch may be inside the door in the door latch unit.
You may have trouble finding vacuum lines. The door unit is electric on 2003.
Old Mar 18, 2011 | 08:30 PM
Bob.H's Avatar
thanks glendoramike I'll stop hunting down an air leak , ha, I actually thought I heard one too ! I did spray all the door mechinisms with AD2000 so now I'll look for the door ajar switch THANK YOU
Old Mar 20, 2011 | 05:56 PM
IrishXtype's Avatar
ok so in the winter sometimes my door mech doesnt allow me to close door ,,I just end up slamming the braket into door hinge...I have to get out , hold my door handle all the way up and phisically push the mechanisim in my door to the unlocked posistion...Make sure all these latches are full up...
No worries we will sort this out...And what part of canada are u in?
Old Mar 21, 2011 | 08:33 PM
Bob.H's Avatar
I have a feelen this is a job for the professionals, could be a switch in the drivers door;it started acting up 2 months ago and its at the point where accelerating from a stop, the door locks click, dome light flashes, door ajar icon flashes constantly on and off maybe it's just the damp weather out here on Vancouver Island
JarodL
Mar 7, 2024 01:39 AM
D.K
Dec 10, 2023 02:05 AM
XJsc-guy
Nov 23, 2015 01:56 PM
tberg
Sep 7, 2015 07:32 AM
bdboyle
Sep 4, 2015 06:16 AM
