Driver Window Noise/Looseness
Old Apr 1, 2013 | 03:54 PM
emaraszek's Avatar
Default Driver Window Noise/Looseness
This has been going on for a while, but now that the weather's getting nicer I'd like to fix it.
Basically if I roll the driver's window all the way up, I get a rattling noise when I go over bumps. I've found that if I just tap the button to lower it for a split second and lower it by even a millimeter the noise goes away. Also, water streaks from outside moisture sometimes appear on the inside of the window.
Any ideas on what it could be? I noticed it shortly after having the tint film removed from my side windows. At first this window and one of the rears used to make a squealing noise when opening/closing which was resolved by greasing the rubber tracks. Was something potentially damaged when the tints were removed?
Old Apr 5, 2013 | 12:08 PM
emaraszek's Avatar
...anybody?
How about detailed instructions for removing the door panel? At least then I could poke around in there and see what's up before resorting to a dealer for service
Thanks in advance!
Old Apr 5, 2013 | 12:45 PM
Lcgi's Avatar
Arrow
Hi Evan,
Could be that the metal links attached to the window are rattling or become loose ?
You would need to gain access behind the door trim - to check that out.
Old Apr 5, 2013 | 04:01 PM
emaraszek's Avatar
Originally Posted by Lcgi
Hi Evan,
Yeah I was thinking it would be easy to spot the issue if I remove the panel from the door with the issue and from the opposite door and compare them.
99xk8guy
Sep 29, 2025 10:51 PM
GordoCatCar
Jan 2, 2017 01:10 PM
Chuck Schexnayder
Sep 18, 2015 03:10 PM
RaceDiagnostics
Sep 13, 2015 02:22 AM
sadepol01
Sep 11, 2015 05:26 AM
