Electric 2.5 SC install
Old Jun 18, 2010 | 09:40 AM
sting19's Avatar
Default Electric 2.5 SC install
I also posted this in the performance area, thought it would get more looks here.
I purchased a 2.5 psi electric supercharger and tried installing yesterday and ran into some issues, has anyone ever installed this before? if so some help would be greatly appreciated.
here is the link where I ordered the sc.
http://www.engineperformancechip.com...r-2-5-psi-p-16.
Old Jun 18, 2010 | 10:12 AM
rothe's Avatar
Your link was broken. I take it that you got this one?
I hate to break it to you, but there's just no way that such a tiny little impeller is going to push enough air to make any difference at anything much more demanding than minimal load, low-rpm cruising. What's more, it looks like there's nothing more than a two-wire installation, which means it's either on or off - no gradual ramp-up of boost like you would have from a belt-driven supercharger or exhaust-driven turbocharger. And I'd venture a guess that it's so restrictive at higher intake demands that you will actually *lose* power, even if it's working "properly."
If you want an even better understanding of why that thing is doing more harm than good, then go to your local library and check out any of the countless books available on supercharging and turbocharging. I'm partial to this one as a good introduction to the principles involved:
http://www.bentleypublishers.com/aut...mum-Boost.html
Bottom line is that you got snookered. Consider it a $225 lesson and move on.
Old Jun 18, 2010 | 11:07 AM
Mikey's Avatar
Electric supercharger scams have been around since the 50s. None of them work for the simple reason that the motor consumes more energy (electricity) than the extra power the engine produces- if any.
Send it back for a refund.
Old Jun 18, 2010 | 05:04 PM
Thermo's Avatar
Veteran: Navy
Sting, I see a few problems with that little gizmo (I am being polite here).
First thing, the little blower that you are looking at is not street legal. If you read the fine print, it says "For Off-road Use Only". Not saying that cops are going to pull you over for having it installed, but if you go through a state vehicle inspection and they spot it, that can be grounds for your car failing inspection.
Secondly, there is no statement about rated CFM at 2.5 pounds of boost. Ask the company how many CFM that is rated for at the stated boost. I bet you will find out that they will do 1 of 2 things: 1) not reply at all to your e-mail, or 2) state that the CFM is something like 50 CFM. Just a hint, your car will need atleast something in the 300 CFM range just to get factory power. Something more in the 500 CFM range is what you would need for more power.
Now, I am by no means an engine expert and know everything there is to know about these 3.0L engines. But, that little toy is not going to do it for you. I could get more boost out of a leaf blower than that thing for the same price.
Sorry to be frank about this, but I hate scammers like this.
Old Jun 18, 2010 | 07:06 PM
Mikey's Avatar
For fun, I did a little research on superchargers. In reference to the manufacturer's typical claim of adding 50 hp, I calculated how much HP it takes to drive a supercharger that would give a net HP boost in this range. The answer is 85.
35HP would be used by the supercharger to drive itself, the 'left overs' would be the net 50 to be used to propel the car
The last 85hp eletric motor I saw weighed about 700 lb and draws around 170 amp continuous current.
99xk8guy
Sep 29, 2025 10:51 PM
dsnyder586
Dec 29, 2024 07:39 PM
99xk8guy
May 28, 2024 09:36 PM
jagtoes
Sep 9, 2015 09:56 PM
mcdutch
Sep 4, 2015 03:38 AM
