Engine lack power
Old Aug 22, 2014 | 02:56 PM
rbhjag's Avatar
Default Engine lack power
My 2002 x type jag not going beyond 3000 rpm and idles rough
Old Aug 26, 2014 | 06:51 PM
gazza836's Avatar
Hi,
I am assuming it is a petrol engined X type.
Check the breather pipe that runs from the cam cover to the inlet manifold as it usually splits and causes an air leak which is too much for the ecm to compensate for and to prevent engine damage it reduces power at @ 3000 rpm (feels quite violent when 3000 rpm is reached).
Hope this helps.
Gary
Old Jul 31, 2024 | 06:07 AM
Dave Parkes's Avatar
Default Same issue
I have the same issue, fine on a long or short run but when I stop at lights or in traffic it will go into what feels like super limp mode, however no codes and it does clear itself when I am slowly able to get up to speed, no idea what is causing it car has a new diesel filter and recent service, it is intermittent but can be dangerous particularly if pulling out from a busy junction. Any help appreciated
Mike367
May 3, 2024 01:17 PM
Mr_Persnickety
XF (X260)
Sep 3, 2021 01:06 PM
marzy2k2
May 7, 2019 01:57 PM
MrRK51
Jul 25, 2018 04:15 PM
harryxtype
Nov 13, 2017 09:48 AM
