Engine running problem
Received 3,842 Likes
argoose, from what you are describing, you have a wire crossed some where. has someone recently done some work on your car? if so, I would take a look in that area to make sure that they haven't pinched a wire or something (this is especially true if they were doing dash work). After that, I would do some looking around under the dash to see if you can spot a wiring harness that is getting pinched and it is leading to wires being damaged.
The two systems are not tied to each other. So, to have a condition like you are saying, some wires are touching that shouldn't be.
rusty37
06-07-2016 04:43 PM
SingBlueSilver
08-27-2015 02:20 PM
