Engine Whine Under Load - Near Waterpump?
Old Feb 11, 2018 | 06:35 PM
AbsoZed's Avatar
Default Engine Whine Under Load - Near Waterpump?
I have an engine sound I can't quite seem to pin down, and it doesn't seem to fit with any that I've seen posted on the forums (I've read a lot since I got the Jag, but figured I'd make an account since this was driving me MAD.)
The sound is what I would describe as a 'belt in distress' coming from the right hand side of the engine bay, but I can't quite isolate it. It SOUNDS as though it's coming from the water pump, but the belt is in excellent condition, and no leaks from the pump or noises there. It's almost as if it's coming from BELOW the water pump. I'll attach a link to a youtube video I have taken of the sound... Let me know if you guys have any input on what I should try.
The sound also happens in neutral, and disappears when you really put the pedal down, it seems like - or is drowned out by the engine itself.
Old Feb 11, 2018 | 07:04 PM
JBzXJ40's Avatar
Hmmm, you say it sounds like RH side, is that RH side while sitting in vehicle, or RH side when looking at engine from front of car?
Water pump is on the back of the engine for this model - driven off camshaft. You can see it next to battery box. If the engine is coming from the front of the engine, seen quite a few idler pulleys fail.
Do you have a stethoscope or a long screw driver? Can use this to pin point the noise.
May also need to take off belt and check idler pulley and tensioner, see if the bearings in them are noisy when spinning by hand?
Old Feb 11, 2018 | 07:32 PM
Dell Gailey's Avatar
Yeah, sounds a bit more like a pully/idler noise to me.
Old Feb 11, 2018 | 08:00 PM
AbsoZed's Avatar
Sorry, should have clarified - right side facing the engine bay.
I've had the belt off that drives the water pump but didn't think to spin anything... What idler pulley are you referring to?
I'm fairly new to this home mechanic stuff... Trying to absorb it all lol.
Thanks!
Old Feb 11, 2018 | 08:05 PM
Idler pulleys/tensioners are on the right side of the car (connected with serpentine belt). Right and left in car speak are always per SITTING in the car. So, if you are positive the sound is on the left, it could be water pump failing. It still sounds more like a bearing whine to me, but water pumps do have bearings, lol.
Old Feb 11, 2018 | 08:08 PM
AbsoZed's Avatar
Yeah, I tried the long tube trick with a piece of radiator hose and it definitely sounds like it's coming from that side. It's only $30 and about an hour to change the water pump so I'll likely try that... Guess I'll find out.
Old Feb 12, 2018 | 02:51 PM
JBzXJ40's Avatar
There is also a idler pulley for the water pump belt, double check this as well. Have seen a few fail, but mostly the water pump. Check the belt too, as most people tend to neglect it.
Good Luck - let us know if you need any more info for disassembly, etc..... quite a few on here who have access to Topix, including myself
silkcat
Aug 5, 2015 08:02 PM
captmal777
Feb 28, 2013 01:57 PM
captmal777
US Western
Feb 17, 2013 12:16 PM
videomaker
Apr 26, 2010 03:57 AM
Dec 1, 2007 06:57 AM
