False Battery Fault
Old Jul 29, 2013 | 07:01 PM
bekcon's Avatar
Unhappy False Battery Fault
I am frequently getting a battery fault light on the dash of my 03 3.0 litre.
I have read the JTIS info and confirmed that I am getting the correct voltages at the battery terminals (13.6v and 15.3v approx) using my digital voltmeters.
Using the on-board test function it appears that the PCM reads the voltage 1 volt lower than actual at the battery which probably triggers the fault light.
There are no fault codes stored.
Does anyone know where the PCM senses the voltage??? If I could find this there is probably a poor connection to be corrected.
Brian
Old Jul 29, 2013 | 07:26 PM
DPK's Avatar
DPK
Brian,
I had an 03,3.0..and it had the exact same problem...Solution: Replace the Battery cables, both the Red ones (+) all the way to the alternator and fuse box, also the Black ones(-) to body and to transmission..this is a classic problem and that will fix it.
Mostly it has been the Red one going to the Starter/Alternator that develops high resistance at the cable ends or connections at the battery terminals (noticeable by blackening or melted plastic on the cable ends...But I changed all the cables out completely to remove all doubt..Lastly, do have your battery Checked, as it too could be contributing to the issue or maybe all the problem is.
picard
Oct 12, 2015 11:56 AM
tonyforman
Sep 10, 2015 07:23 PM
skadmiri1
Sep 9, 2015 11:27 AM
OkieTim
Sep 8, 2015 04:48 PM
OkieTim
Sep 2, 2015 12:48 PM
