Fan module
Old Aug 8, 2014 | 11:16 PM
billbjork's Avatar
Default Fan module
Well guys I finally got the correct fan module and got it installed. The supplier had sent me a updated module but it must have been have been a after market and was matched with fan the assy. off the donor car as it came with NO wires. Anyway I finally got the correct one from a 05. The fans run, problem solved.
For all the techno Geeks and do- it -yourselfers the problem was a failure of the J gate on the Mossfet not saturating to allow the amperage to ramp up to run the fan/fans. I wired (the old one) to a 12V power supply and supplied a trigger circuit and got 12v to the the fan wires(even connected a small fan) the fan would bump but not turn because the Mossfet wouldn't allow any amperage. This was proof enough for me so I was reassured the new one would work and it did.
As long as I had the air dam off the bottom and had a fog light out so I removed both and I was glad I did, the drivers side one was completely corroded. I took me while with contact cleaner,small screwdriver to get it clean. The hardest part of this project was getting the right part
hoodun
Nov 20, 2022 02:35 PM
Seth
Nov 1, 2015 12:17 PM
leep123
Sep 30, 2015 03:41 PM
zdrapec
Sep 25, 2015 05:49 AM
