Fault code p1647 help please
Old Mar 5, 2018 | 09:24 AM
Slownot's Avatar
Default Fault code p1647 help please
I've just replaced the correct o2 sensor with a brand new oem specification sensor , starts and run fine , then the dashboard all fails with engine running ok
Reading through there seems a problem with bad earths can cause this to happen, looking through my manual , can't seem to locate earth points , could someone possibly point out the earth point locations do I can thoroughly clean up , thank you
Old Mar 5, 2018 | 10:58 AM
wa3ra's Avatar
Was the sensor a Denso? Bosch sensors say they are OEM spec, but wi;; light your dash up like a Christmas tree.
Old Mar 5, 2018 | 11:01 AM
Slownot's Avatar
Yes it was a denso , genuine had read an awful lot about using genuine , so I stumped up the cash
Old Mar 5, 2018 | 11:47 AM
wa3ra's Avatar
Use a little contact cleaner in the socket, plug it in and unplug it a few times to clean up the contacts; when you get a good contact, the lights should go out.
The Bosch heaters have a very different resistance across the heaters, that is why they cause so much grief.
Old Mar 5, 2018 | 12:52 PM
Slownot's Avatar
Socket from o2 sensor yes ?
Any other terminals to clean up , can't understand why instrumentation would fail
Chrys
Jan 10, 2021 11:11 AM
suiteddeuces
Aug 31, 2016 01:24 AM
80sRule
Jun 18, 2016 10:19 AM
pnfootitt
Sep 6, 2014 11:19 AM
morales8416
Nov 17, 2011 03:04 AM
