Fixed P1647 for cel and now have 4 new codes
Old Aug 12, 2016 | 02:37 PM
Gman1957's Avatar
Default Fixed P1647 for cel and now have 4 new codes
Had a cel on my 2005 x type for P1647 so I replaced the 02 sensor, drove around some and then did a code check to remove it. It now shows 5 codes so I just deleted them all and the cel goes off and I drive around some with no light coming back on. 1 day later cel is back with P0170 thru P0174 and if I delete the codes before driving the light stays off. car drives fine no loss of power or rough idle, any insight?
Old Aug 12, 2016 | 08:26 PM
clyons's Avatar
I would suspect that in changing the O2 sensor you disturbed something in the air intake system. P0171 and P0174 (I can find no listing for P0170) indicate lean mixture on both banks. A usual cause is a vacuum leak. After clearing the codes the CEL will come back after 2 drive cycles if the problem still exists. A search for those codes will reveal many threads that discuss causes and fixes, but I would check anything that was removed to access the O2 sensor.
Old Aug 12, 2016 | 11:03 PM
Gman1957's Avatar
Thanks I know from being around the p0170's usually indicate a vacuum leak, I just don't understand how removing the air box could create all the mess. I'll check the usual suspects and check for any lose connections. Thx clyons
Old Aug 14, 2016 | 02:19 PM
Gman1957's Avatar
Found vac leak in the check valve coming from the brake booster. I mixed some 2 part epoxy and put it on the holes on the check valve and let it cure. Problem is fixed for now, I'll replace that assemble when the parts come in.
Dean Kitching
Mar 30, 2016 02:53 PM
xjmaz
Diesel variants - All models
Mar 27, 2016 02:53 AM
Nookpad
Mar 26, 2016 11:55 PM
racerx82
Sep 13, 2015 06:26 AM
May 24, 2006 02:08 AM
