Fluids - Transfer case, Manual Trans, Gear Box....
Old Feb 16, 2012 | 03:59 AM
aadish's Avatar
Default Fluids - Transfer case, Manual Trans, Gear Box....
Hi All,
Can somebody advise on the Jaguar recommended fluids as well as the approved (or at least tested) other brands with exact specs for the following:
  1. Transfer Case fluid:
  2. Manual Transmission Fluid:
  3. Automatic Transmission Fluid:
  4. Gear Box Fluid (Manual Trans):
  5. Differentials:
Thanks for all your inputs.
Old Feb 16, 2012 | 05:55 AM
Thermo's Avatar
Veteran: Navy
1. Full synthetic 75W-140 gear lube (meeting "M2C 192A Synthetic"). Pretty much, this is any full synthetic gear lube out there.
2. Castrol BOT 130M fluid.
3. ATF IDEMITSU K17 (Jatco 3100 PL085). As I recall, this is your standard Mercon V fluid which is a full synthetic tranny fluid. If it has the Mercon V seal on it, you are good to go.
4. Same as stated in 2.
5. This also uses the 75W-140 fluid as stated in 1. As long as it has the GL specification called out on the bottle, you are good to go. That will meet all the requirements that you will need for the car.
Old Feb 17, 2012 | 07:06 PM
aadish's Avatar
Thermo: Any opinion on Red Line MT-90 for bullets points 1 and 2?
Old Feb 17, 2012 | 10:12 PM
MarkC's Avatar
I used MT-90 in my manual transmission. It seems fine. Perhaps a slight improvement in shifting.
Old Feb 18, 2012 | 03:32 PM
Thermo's Avatar
Veteran: Navy
aadish, never used the product, so, I can not give an opinion either way.
Old Feb 19, 2012 | 05:01 PM
aadish's Avatar
MarkC: I bought a RedLine MT-90. I am going to replace the manual trans fluid sometime this week. I have read conflicting reports of how much fluid is needed, a quart or two? Also, the tran fluid is drained by opening loose the drain hex nut at the bottom right?
Old Feb 20, 2012 | 03:46 PM
rothe's Avatar
MT-90 is a GL-4 oil typically used for manual transmissions, and is the appropriate viscosity for X-Type manuals. It is not appropriate for either the transfer case or the differential. You will need 1.8 qts for the manual transmission.
Of Redline's products, 75w140NS is the appropriate weight oil for the transfer case and differential. It is a GL-5 oil, which will sustain the higher pressures of those applications. The transfer case takes 0.6 qts, and will expel any excess out the vent hole at the top of the transfer case. If you overfill, it may take several weeks before you stop smelling excess, vented gear oil, but you won't hurt anything beyond causing a stain on your garage floor.
FWIW, the rear differential takes 1.2 qts.
Do yourself a favor, and order an extra quart of 75w140NS for the transfer case. It's too easy to spill the whole load when you're filling the case from the drain plug, as is typical of some filling procedures.
*Do your homework about the fill procedure BEFORE you pull that drain plug!*
aholbro1
Dec 29, 2024 06:46 PM
bamforp
Aug 14, 2024 05:36 PM
Jandreu
Jun 30, 2022 03:10 PM
neruda
Oct 18, 2015 01:19 PM
Wes Steenrod
Sep 6, 2015 06:52 PM
