foggy windows and ice built up on windows help??
Old Jan 14, 2009 | 03:33 PM
perezrp101's Avatar
Default foggy windows and ice built up on windows help??
Yes i have a 2002 x-type and for some reason my windows fog up then ice starts to build up in the winter does anyone know how or why this happends helps i cant fit scuba gear in my car.
Old Jan 14, 2009 | 06:18 PM
Dennis's Avatar
ud
Default RE: foggy windows and ice built up on windows help??
Deja Vu..
Check this out.. https://www.jaguarforums.com/m_86581/tm.htm
Old Jan 14, 2009 | 09:30 PM
Real_Tech's Avatar
It happens most commonly because the recirc flap is stripped where the stepper motor engages the flap and the recirc flap is stuck in recirc mode and breathing in the car causes excess humidity. You can test this easily. Remove the cabin filter. This is under the wiper cowl on the passenger(LHD) side. After the filter is removed look into the opening behind the filter that is covered by a plastic grate. If the opening is blocked by a white panel the recirc door is shut. Turn the ignition on without starting the car and select 65 degrees then press the recirc button so it is lit red. This will close the recirc door then press again so it is not lit and look in the filter opening again. If it is still blocked by the white door it is stripped. For a down and dirty quick fix reach through the grate with a screw driver and push the door upwards to open it. Don't worry, it is already stripped and will move easily. This will correct the problem until either recirc is selected with the button or hot weather arrives and a/c is used on high setting. At least you wont have to scrape the inside of the windows for the rest of the winter. There are more permanent fixes available but try the diagnosis first and we can go from there.
philwarner
28
Jul 11, 2017 10:21 AM
NS2000XKR
Jan 1, 2017 10:41 AM
MrWhite
33
Oct 22, 2015 10:29 AM
blackenedindustries
Sep 30, 2015 10:17 AM
