freeezing cold
Old Aug 20, 2014 | 06:11 AM
alancamuk's Avatar
Default freeezing cold
Hi there. I own a lovely midnight blue x-type 2.2 diesel sport on a 55 (2006) plate.
in the last week, i've had the clutch and flywheel replaced, and the battery as at 8 years old it fianlly refused to hold a charge.
the problem is now the climate control will olny fire refrigerated air.... even when set at 27 degrees...i'm presuming it's more to do with the battery change,,, but it switches on fine, and i can switch it off etc the fans fire up, but when i select air con, it just blows cold.... any suggestions, that dont involve another £££'s garage visit?
Old Aug 20, 2014 | 04:06 PM
Thermo's Avatar
Veteran: Navy
Alan, one of the first things that I would tell you to do is to dial the temp dial as low as it will go and wait a few seconds, then raise it to the maximum temp that you can get, then dial it all the way back down. This will cause the A/C computer to re-calibrate itself and that will hopefully fix your temp issue. If it doesn't, then let us know and we will take things from there.
Old Aug 21, 2014 | 06:10 AM
alancamuk's Avatar
Thanks for the reply. i dont have a dial, i have buttons. and will definately try this though.... does air con need to be on or just hold the buttons in until they reach high or low?
Old Aug 21, 2014 | 06:43 AM
Davidsw's Avatar
This shows how to do the self test of air con . I hope it helps with your car .
X300 Air Conditioning Self Test and Diagnostics ~ Jaguar Vanden Plas "The cats meow"
Old Aug 21, 2014 | 03:46 PM
astromorg's Avatar
Sadly this does not work for the X Type AC system!
redxk8
Oct 4, 2015 08:28 AM
inactualis
Oct 2, 2015 11:13 AM
Johncy2000
Oct 2, 2015 01:05 AM
42Ajd
Sep 26, 2015 07:04 PM
