Front wheel bearing
Old Sep 28, 2015 | 08:11 PM
Corycarlo's Avatar
Question Front wheel bearing
I'm planning on removing the front spindle and taking it with the bearing to the mechanic and having them change it. Where can I get a cheap decent bearing with the required meganetic strip and what's the spindle removal procedure?
Thanks guys
Old Oct 1, 2015 | 10:00 PM
Corycarlo's Avatar
Bump
Old Oct 2, 2015 | 09:27 AM
Thermo's Avatar
Veteran: Navy
Cory, your local auto parts store should be able to help you out. Otherwise, E-bay or Rockauto are going to be 2 more places that you can get it for fairly cheap.
Old Oct 3, 2015 | 06:02 AM
Corycarlo's Avatar
I've found them on eBay and Amazon and even tho they state its for the x type so reviews said it didn't have the mag strip. Just didn't want to get the wrong one. And just really want to get the best deal on the right one. Thanks
Old Oct 3, 2015 | 08:12 AM
Thermo's Avatar
Veteran: Navy
Cory, keep in mind that those that posted that the bearing didn't have the magnetic strip probably had their mechanic install the bearing backwards. There isn't a magnetic strip inside the bearing. What is happening is the sensor has a magnet inside the tip and as the internal of the bearing roll by (there is a small toothed gear as I recall), the sensor sees the teeth and counts them. These teeth are on one end. So, if you install the bearing backwards (the bearing is labeled as what is the inside part, what is the outside part), those teeth are too far away for the sensor to see, so the sensor sees no motion even though the bearing is spinning.
Look at: Wheel Bearing Front TIMKEN WB000003 Fits 02 08 Jaguar x Type | eBay
In the listing, you will see where it talks about "interchange number". This is a number that all the manufacturers will follow if they say that part A is the same as Part B. For example, the Timken bearing WB0000003 is the same part as the SKF FW501. Just made by 2 different manufacturers. You order either one of these bearings, you will get the correct part. You have like 5 bearings to choose from, all made by different manufacturers. I tend to stick with Timken and SKF just because I have used them in the past and haven't had any major issues with them.
Old Oct 3, 2015 | 10:14 AM
Corycarlo's Avatar
Good to know, thanks!
Old Oct 3, 2015 | 09:33 PM
Dr dome's Avatar
skf is the best.... My friend works there. haha
PMKimpton
Aug 3, 2019 08:22 PM
Harry Dredge
Sep 3, 2015 03:04 AM
Harry Dredge
Sep 2, 2015 02:26 PM
innzane
Sep 2, 2015 10:08 AM
