fuel
Old Mar 16, 2014 | 01:09 PM
teddyboy's Avatar
Default fuel
does the fuel range stop working if fuel is low its just on red and ive noticed its only showing mileage now.
Old Mar 16, 2014 | 01:22 PM
Welcome to the forum teddyboy,
I've moved your question from Jaguar Forums Advice / Feedback & Suggestion Center to X-Type forum. The Advice / Feedback & Suggestion Center is for posts about the forum and not for tech questions.
Members here with the same model will be able to help.
Old Mar 16, 2014 | 02:40 PM
Redthing's Avatar
I usually have my fuel range displaying and it has always worked when the fuel reserve light comes on....usually comes on right around 35 miles to go. If I understand you correctly, you have the odometer reading displayed. Try hitting the "Trip" button on the turn signal column switch.
Old Mar 16, 2014 | 03:46 PM
Thermo's Avatar
Veteran: Navy
teddyboy, I leave my car pretty much on MPG reading, but when I am getting close to empty, I will switch it over to watch the miles left and you can take it to 0. It doesn't cut out at some lower value. Some cars will do that so it makes it so you can't try and take it right to the end. But, these cars actually have about a gallon or so after it says 0 (car has a 16 gallon tank and even taking it to 0, I have only been able to put 14.5 gallons into it at best).
Ragn0r
Sep 29, 2015 10:38 AM
moff1959
Sep 26, 2015 05:35 PM
XKE73EIconverter
Sep 26, 2015 10:21 AM
reb1999
Sep 26, 2015 08:41 AM
reb1999
Sep 25, 2015 10:00 AM
