Fuel Injector O-Rings
Old Apr 19, 2010 | 10:15 AM
Karmak's Avatar
Question Fuel Injector O-Rings
Does anyone know where I might be able to get a set of fuel injector o-rings? Jaguar does not offer the part as they are not serviceable . After looking online and locally it appears they suggest the top and bottom o-ring are the same size. The bottom (intake) o-ring on my injectors are much thinner then the top (fuel rail) and a different color.
This is what the top o-ring looks like on mine except they are blue. I assume the color doesnt matter.
These look exactly like the bottom. Notice how they are much thinner.
I will take a picture of them when I get home.
Old Apr 19, 2010 | 04:43 PM
Thermo's Avatar
Veteran: Navy
karmak, see if you can get some o-rings for a Lincoln LS 3.0L motor. I bet you will find that those o-rings are the same ones that you need.
Old Apr 19, 2010 | 07:28 PM
Karmak's Avatar
Here is what I am dealing with. Auto Zone, Advanced, PepBoys and Napa all offer a black version of the blue o-ring below. I had them check the 2003 Lincoln LS 3.0 and a few other cars they all came back with the same part. I cant find a replacement for the smaller black o-ring .
Old Apr 19, 2010 | 09:09 PM
Thermo's Avatar
Veteran: Navy
As for the blue o-ring, that looks a lot like the o-rings used on a 5.4L engine used in the ford trucks (F-150, Expedition, Navigator, F-250/350). So, you may want to take the o-ring in and see if they can pull down a box of those o-rings and see if they match up.
As for the thinner (black) o-ring, you should be able to go over to the o-ring center at your local parts store and find something that is really close. Most of the o-rings that you will find are going to be nitrile o-rings and they will stand up to gasoline.
Another option is to talk to ken@britishparts.com. I'm sure he can get you the o-rings.
Old Apr 19, 2010 | 10:30 PM
Bruce in North Dakota's Avatar
From: That Rectangular Hole in the Consciousness of America
For weird O-rings, I have always had luck with Caterpillar equipment service centers.
Heavy equipment comes from all corners of the globe anymore, and they - in particular - seem to have the best stock and assortment of O-rings to service them.
Here's an interesting video "When O-Rings Go Bad". Very educational.
Part One: http://www.youtube.com/watch?v=Pg_xl31f5po
Part Two: http://www.youtube.com/watch?v=oZMaPlZz1XQ .
Good Luck!
Old Apr 21, 2010 | 01:38 PM
Karmak's Avatar
Unhappy
I called Ford to see if they can get me a set of o-rings for a 2004 Lincoln LS 3.0 They can get the top (blue in my picture) o-ring that I can find just about anywhere around here. The smaller bottom ring (black) is not serviceable and do not offer replacements . They would have to order a whole new set of injectors to replace the o-ring. I get the same answer from Jaguar and britishparts. I have gone to local shops that specialize in injectors and others that have random o-rings and none carry the correct size for the smaller ring. Any other suggestions?
Thanks!
Old Apr 21, 2010 | 06:19 PM
Sandro's Avatar
Try calling RC Engineering http://www.rceng.com/directory.aspx
They may be able to help you out.
- Sandro
Old Apr 21, 2010 | 09:41 PM
Karmak's Avatar
Found the o-rings at a local bearing shop of all places. If anyone ever comes across this post and cant find them locally send me a message. I would be more then happy to grab some and ship them out.
Old Apr 22, 2010 | 06:49 PM
marnaf's Avatar
Default I'm in the same boat with a XJ8 l 2000
I'm having problems to find the fuel injector seal for a Jaguar XJ8L 2000 in arizona.
The jaguar dealer said me that I must buy the fuel injector in order to got the seal.
I appreciate if you can help me to find these O-ring.
Marnaf from Nogales , Arizona
Old Apr 23, 2010 | 11:34 AM
marnaf's Avatar
I need the o-rings for a Jaguar XJ8L 2000 can you share the phone number from your local bearing shop?
Marnaf from Arizona
Old Apr 24, 2010 | 08:46 AM
jn_lego's Avatar
you mentioned in the first post that jaguar said the injectors are not serviceable, does this mean no fuel injector cleaning, or if an o-ring goes bad time to buy new injector?
Old Apr 24, 2010 | 12:21 PM
Karmak's Avatar
Smile
marnaf
I dont have access to a XJ8 so I have no idea if they are the same injectors. If you can read the numbers off the side I can compare them to mine. I got the o-rings from Tri State Bearing 812-425-1336. If you call and ask for injector o-rings I doubt the will be able to help without being able to compare the old to what they have.
jn_lego
That is correct. If for any reason you need the lower o-rings Jaguar expects you to spend $1200+ on a whole new fuel rail and lower intake assembly + Injectors. I might be wrong on exactly what the $1200 includes I was in shock when I heard the price. This is also true for the Lincoln LS 3.0. So far the o-rings I got are working perfectly . No leaks or issues when reinstalling the injectors.
I used this video ( http://www.youtube.com/watch?v=VFJlTfHyrUk ) and had to make a few modifications. In the end I was able to test and clean all my injectors.
Old May 16, 2011 | 05:39 PM
jfenley's Avatar
Default They do exist!!!!
I found them at drivewire.com (00 2000 Jaguar S-Type Fuel Injector Seal - Fuel Injection - OES Genuine | Drivewire.com ). Yes, these are for the "s-type" but they are the same as the x-type. DO NOT look for them after 03 -reason most of our online supply shops go by MFR's report as non serviceable. When in fact the MFR used the very same injectors for several years. I have them in my 07 x-type! Same injectors as my 02 x-type and my 04 s-type. Go figure! I'm not too suprised. Here are the web-site pics.
Click to enlarge
Old Feb 24, 2016 | 06:40 PM
jfenley's Avatar
Default Fuel Injector O-rings
I happened to look at this post today and found out that the "enlarge" photo is pretty bad and you can't see information. so here it is:
currently, Auto Parts Warehouse sell them for 6.95ea
Lower
Upper
log-in to their site and search for : "OES Genuine W0133-1655730" & "OES Genuine W0133-1655731"
in a pinch you can also search the web using those #s
Part #: W0133-1655730
OES Genuine Fuel Injector Seal Fuel Injector Seal
OES Genuine
Qty: 6.00
Price: $ 6.95
Part #: W0133-1655731
OES Genuine
Qty: 6.00
Price: $ 6.95
Old Apr 14, 2017 | 12:38 PM
Kyle Tice's Avatar
Default I know this is an old thread
Do you be chance remember the smaller o ring specs
Old Apr 15, 2017 | 07:08 AM
jfenley's Avatar
Kyle, no I never SPECed the O rings but did provide you with a means to locate the parts. A quick google search on the part numbers provided turn up the parts. If your plan was to replace with O-rings from an o-ring kit, I would caution you on that. O-Rings due have SPECs like hardness, and material used. Don't be concerned when the O-rings fit the s-type or other models, I had an S-type and 3 x-type, these O-rings are common throughout the entire series and years. Still the same. Here is a list I turned up from my search this morning:
BLUE - Upper
http://www.carparts.com/details/OES_...upon&TID=iraff
https://www.newegg.com/Product/Produ...9SIA91D3BH2248
2000-2002 Jaguar S Type Fuel Injector Seal - Fuel Injection - Genuine, Upper 00-02 S Type Fuel Injector Seal - 545-01003066 - PartsGeek
https://www.amazon.com/OES-Genuine-Injector-select-Jaguar/dp/B001G7D87S https://www.amazon.com/OES-Genuine-Injector-select-Jaguar/dp/B001G7D87S
BLACK - Lower
https://www.newegg.com/Product/Produ...9SIA91D3BH2263
https://www.amazon.com/OES-Genuine-Injector-select-Jaguar/dp/B001G7F6PU https://www.amazon.com/OES-Genuine-Injector-select-Jaguar/dp/B001G7F6PU
2000-2002 Jaguar S Type Fuel Injector Seal - Fuel Injection - Genuine, Lower 00-02 S Type Fuel Injector Seal - 545-01003067 - PartsGeek
there were many more hits, this is just a few. Sorry I cant give you the information you requested "SPECS". I never researched that information, I just wanted back on the road
Old Jan 29, 2020 | 12:27 PM
Vic Douse's Avatar
Old Oct 7, 2021 | 06:24 PM
dh53's Avatar
I know this is a very old thread but I found it when looking for injector O-ring info. Upper O-rings are sold as O-rings, lower O-rings are usually called seals even though they are just different O-rings. Upper O-rings are very easy to find, lowers not as easy but are available from the usual Jag specialty shops: SNG Barratt, jagbits, terrysjag
Upper Injector O-ring: C2C19756
Lower O-ring / seal: C2C19757
GB Remanufacturing sells both as a set, their part number 8-051. Right now a set of these at Rock Auto is $3, less than either an upper or a lower from the Jag parts suppliers. GB Remanufacturing has a buyers guide listing all the applications with the same O-rings. The list is pages and pages long. Here in the US of note they are the same as the O-rings on the 2003-2010 Ford F-150 5.4L which was the largest selling vehicle in the world for most of those years, so there must be some inexpensive Ford aftermarket parts.
Old Oct 8, 2021 | 07:48 AM
Thermo's Avatar
Veteran: Navy
dh53, if that is true about the fuel injector being used on the F-150, then simply walk into your auto parts store and tell them that you have a 2012 F-150 5.4L and you need the o-rings. tada, I bet you will get a set. I have done this for a number of other parts but told them that I had a Lincoln LS 3.0L motor. That may be the other model that I would let them look up and see if they have the o-rings for that.
Old Oct 8, 2021 | 10:56 AM
dh53's Avatar
You're right, the Lincoln LS 3.0L is also on the list as are XK8, XJ8, S-Type, Jeeps, Fords, Chevys, Mazdas, Mitsubishis, Land Rovers, VWs... Makes sense, these things get cranked out by the millions by Denso and Bosch and are mostly specific to make and model by the internals of the injector, not by differences in the external dimensions where the seals engage.
The list says:
F-150, 5.4L, 2003-2010
F-150, 5.0L, 2011-2017
There are several more F-150 model years and engines on the list but you get the point. Don't ask for 2012 F-150 5.4L seals, ask for 2012 5.0L seals.
